E46 Convertible
Old 08-30-2013, 02:18 PM   #1
PapiOcho
My Ride: CRV
Normal Window function
So last night I was out on the town with the top down.
I needed to get into the passenger side. With the top up. The door opened normally or so I thought. When I closed it didn't exactly close all the way. The window didn't dip down to clear the top like it's supposed to.
I lowered it using the switch and the door functioned properly.
I raised the window and tried to close the door again. And again the window didn't dip down to clear the top, in fact the door latched and the window remained outside the top and the window channel.
QUESTION: What tells the window to move down when the handle is actuated?
I got the window to seat properly by lowering it first. Drove about 20 minutes back home. I parked and tried to cause the window to "fail" again but it wouldn't.
Experiences? Opinions? Options?
PapiOcho is offline   Reply With Quote
Old 09-02-2013, 01:18 PM   #2
PapiOcho
My Ride: CRV
Re: Normal Window function
No ideas?
I haven't driven the car since. SO I guess I'll keep an eye on it.
Old 09-02-2013, 01:44 PM   #3
cityjohn
My Ride: 2001 M3
Reset it so it knows its limits. Window needs some discipline!
With top up, ignition on and doors closed, sit inside and lower passenger window. Now raise it by holding the switch; when it reaches the top keep holding the switch for 5 seconds. Might have to do this procedure a couple of times.
This should set the auto-down function as well as the dropdown feature.
cityjohn is offline   Reply With Quote
Old 09-02-2013, 01:49 PM   #4
PublicStellar
My Ride: 04 330Ci SSG, R1200C
Mine has done this occasionally, no rhyme or reason.
I wish you success! Post when/if you find something.
PublicStellar is offline   Reply With Quote
Old 09-02-2013, 02:31 PM   #5
PapiOcho
My Ride: CRV
@cityjohn. LMAO lumosity for my car!
I'll give it a shot. Can't hurt.
I recently decided that this car is league's more intelligent then I!
