Sponsored by BimmerWorld
Old 08-31-2013, 04:37 PM   #1
Jaredxxx24
My Ride: 2000 323i
overtightened and stripped brake bleeder screw- do I need a new caliper?
so today I was doing a brake fluid flush and when I went to tighten the bleeder screw it was quite obvious that it was stripped out internally. I didn't even tighten it that much either. do I need a new caliper now or can I get away with just buying a new screw?
Jaredxxx24 is offline   Reply With Quote
Old 08-31-2013, 05:36 PM   #2
jdstrickland
My Ride: '94 325iC & '00 323i
Don't you suppose that depends on what is stripped?
If the thread of the bleed screw are all that's stripped, then put a new one in. No matter what, put a new one in. If it fixes the trouble then you are home free, if not then you need a caliper.
Old 08-31-2013, 10:36 PM   #3
bimminge46
My Ride: 323Ci, 89 325i ETA
If the threads on the caliper are stripped, remove the caliper and retap it to a new size which will depend on the new bleeder. If it were me I'd just buy a new caliper since they aren't that expensive.
E30 in progress.
bimminge46 is offline   Reply With Quote
Old 08-31-2013, 10:43 PM   #4
wildirish317
My Ride: 2004 325Ci vert
Even if this works, order a new caliper and replace it. Brakes are something you don't want to "fix".
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 08-31-2013, 11:57 PM   #5
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
get a reman caliper from NAPA. it's less than $50 and will be all good.
Old 09-01-2013, 12:03 AM   #6
motorhead55
My Ride: 01 325it 5spd sport
If the bad caliper is on the front, I would HIGHLY recommend replacing them both. The problem with only replacing one on a steering axle is that one caliper might move internally easier than the other and cause steering pull when braking. You should not have to crank on them when seating the bleeder screw. DO NOT tap it out bigger!
motorhead55 is offline   Reply With Quote
Old 09-01-2013, 12:06 AM   #7
peytonracer4
:D
My Ride: '00 328i
if the brakes have been properly maintained, they should both move with the same effort.
Old 09-01-2013, 02:56 AM   #8
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
14 y/o car that's been through who knows how many owners - I wouldn't bet that they've been maintained properly. I doubt it would pull either way though, as long as you clean up the sliders on the other one and re-lube them, it will be fine.
I most enthusiastically agree about not trying to repair the caliper. Even if you don't care that it's going to totally screw over the next guy when he wants to get new brake lines - there's no way you're not gonna get chips in the hole from drilling and tapping the new thread. That means you need to pull the caliper apart completely anyways which means new seals, and a good cleaning, getting all the rust off, and now it's become too much of a pain. Just get a new caliper.
Cavi Mike is offline   Reply With Quote
Old 09-01-2013, 12:37 PM   #9
Alex323Ci
My Ride: M3 & 323Ci (sold)
bleed screws are a softer metal (usually brass) and they give out before the caliper threads. it's very likely you just need a new bleed screw.
if for some reason the caliper is stripped I'd do like has been suggested and buy a remanufactured one/used because they're so inexpensive.
