Old 08-31-2013, 05:29 PM   #1
North Coast Cab
My Ride: Porsche
Factory HID Headlight Issue
My '04 330 has the factory HID lights.
The passenger one went out, no light out indication on dash.
I swapped the bulb, nothing.
I swapped the red/blk square ballast(?) side to side and no luck.
Is there an ignitor or something else I can check?
Also, wiring is very very brittle and I have been taping and insulating bits of it the last year or so as the insulation has broken off.
Thanks!
North Coast Cab is offline   Reply With Quote
Old 08-31-2013, 06:32 PM   #2
eneka
My Ride: 2003 325i
yes there is an ignitor within the headlight. It the part the twists onto the bulb. Do you have ZKW projectors? If so they might be burnt out as well.
eneka is offline   Reply With Quote
Old 08-31-2013, 07:29 PM   #3
afstud
My Ride: 2003 ZHP 6-speed
It's probably easier to take the faulty headlight completely out and plug it into the side with the working headlight. Then determine what's wrong
2003 330i ZHP 6 speed
afstud is offline   Reply With Quote
Old 09-02-2013, 07:56 AM   #4
North Coast Cab
My Ride: Porsche
Thanks. Not sure what the ZKW projector is.
The bulb is a D2S.
So the ignitor is the black ring with the small metal contact area?
Old 09-02-2013, 06:19 PM   #5
North Coast Cab
My Ride: Porsche
So I swapped bulbs and they are both good. I swapped Red/Blk ballasts and they are both good.
I went through the wiring and checked all the connections and heat shrinked the wires so everything looks well insulated.
Not sure where to look now?
