Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 244 votes, 5.00 average. Display Modes
Old 10-08-2013, 10:21 PM   #41
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Originally Posted by aa34s View Post
Nice information and write up.
Thanks...
Ok guys here is the wiring info for the Can Bus V2 to get the reverse camera to work, thanks to Tnhl1989!
The Orange wire is needed to have the reverse camera working with the new canbus v2 and harness. I soldered a Blue wire to the Orange (reverse) wire and connected to a Blue/Yellow wire in the glove box
Shown in the diagram below is the wiring to the reverse light. This box is on top of the fuse box.
Soldered a Blue wire to the Orange (reverse) wire and connected to a Blue/Yellow wire in the glove box.
Build Thread - S54 Vanos Thread
TTFS Engine/SMG Tune - SGT Headers/Sect 1/SCZA - Evolve Eventuri - Sprint Booster V2
UltraGauge - Orion V4's - CF Lip/Console/Diffuser - VIS XTS CF Hood - CSL Trunk - Valentine One - Turner 15F/12R Spacers
WOLFN8TR is offline   Reply With Quote
Old 10-09-2013, 01:13 AM   #42
shingo43
My Ride: 04 325ci
I saw in 5150 on the left bottom there is a "mic" label, does that mean there is an front mic so I don't need to wire the external mic?
shingo43 is offline   Reply With Quote
Old 10-09-2013, 07:23 AM   #43
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Yes Sir...
Old 10-09-2013, 07:25 AM   #44
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Yes Sir...That is a Mic.
Old 10-09-2013, 11:15 AM   #45
shingo43
My Ride: 04 325ci
How do I know which relocate part I need? I cannot tell the difference between smoker one and the non-smoker one?
Does smoker one have led light and non-smoker one doesn't? my doesn't
Old 10-09-2013, 01:57 PM   #46
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Correct. I ordered the non-smoker one by accident and it didn't have the hole for the ash tray led. I had to drill a hole to install my led. That was the only difference.
Old 10-09-2013, 02:40 PM   #47
aa34s
My Ride: 99 328i
Is it really need the relocation kit for the HVAC or I can mod the original to fit in??
aa34s is offline   Reply With Quote
Old 10-09-2013, 03:25 PM   #48
shingo43
My Ride: 04 325ci
Do you mind shot me a picture? Thanks
Old 10-09-2013, 04:57 PM   #49
daki_bmw
My Ride: 330Ci
No, you don't HAVE TO...Check this vid (0:50 - 2:30 talks about relocating A/C unit):
daki_bmw is offline   Reply With Quote
Old 10-09-2013, 05:37 PM   #50
shingo43
My Ride: 04 325ci
Thanks for the video, I didn't fully understand it, It says you don't need to keep "this" and "that", what exactly are they?
Old 10-10-2013, 09:41 PM   #51
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Sure. What exactly do you want a pic of? Ash tray?
Old 10-11-2013, 06:48 AM   #52
daki_bmw
My Ride: 330Ci
I think that "this" and "that" are clips that lock into relocation unit, which you can't "lock" using non-relocation unit. You can still make it sit nice, straight and flush without it, too...
Old 10-11-2013, 03:27 PM   #53
shingo43
My Ride: 04 325ci
oh I was wondering the difference between the relocator, and wanted a picture to show the differences.
I've checked and my car has a small orange light in the ash tray so I guess mine is the smoker version.
Old 10-11-2013, 06:06 PM   #54
toze777
My Ride: 320D ( E46)
I originally installed the GPS Antenna inside on the dash by the passenger A pillar. This worked ok but I decided to mount it on the roof in the front of the car. This was actually pretty easy, it took about 15 minutes to complete and the signal is better. All the wires for the backup camera, GPS, USB and iPod ran down to the passengers side behind the glove box.
Mount the GPS Antenna and run the wire down inside the window seal into the engine compartment. Then thru the rubber grommet inside the small compartment on the passengers side. There are two unused access slots, just cut the tip off one and run the cable thru. See below.
Nice ,, That Gps would last long here in Portugal like that some would jut cut it and take it over night .. but till good idea
toze777 is offline   Reply With Quote
Old 10-17-2013, 04:21 PM   #55
CBLKE46M3
My Ride: E46 M3
First off thanks for the great write up!!
Hey a few questions...
1. My car is a 2001 M3 with Factory GPS retrofit from a 2004 model, is there a particular harness I need?
2. Anything needed for a HK System? Line out converter etc? Or simple Plug and play?
3. Does the blue tooth work just fine? (I have galaxy S4)
4. Does the IGo maps come pre loaded on a SD card when you purchase directly through Eonon?
5. Can you change the clock look? It just looks so silly/cheap.
6. Are steering wheel controls retained?
7. Is the a group buy?
CBLKE46M3 is offline   Reply With Quote
Old 10-19-2013, 12:40 AM   #56
wicked_ink
My Ride: 2002 325i
Thanks for puting this together WOLFN8TR! Great job!
Quick question, is there a 12HR mode for the clock or is it just 24HR mode?
Thanks,
Mike
wicked_ink is offline   Reply With Quote
Old 10-19-2013, 07:38 AM   #57
therealet23
My Ride: BMW M3
Thanks,
Mike
Yes in the settings...
The clock is kind of weird as I can never get it to be correct when it is synced to the GPS...
therealet23 is offline   Reply With Quote
Old 10-19-2013, 01:13 PM   #58
wicked_ink
My Ride: 2002 325i
Re: Eonon D5150 Install
Cool, thanks.
Sent from my Galaxy S4 using BimmerApp
Old 10-19-2013, 02:54 PM   #59
Mr. Danutz
My Ride: BMW E46
Eonon D5150 Install
Hello,
My name is Dan, and I'm from Romania. First of all, i want to appologise my english.
@WOLFN8TR - your informations about the product and the instalation are very great, and i want to thank you very much fort that. Monday arrives my D5150 and your tips are going to be very usefull.
A++++++++++
Mr. Danutz is offline   Reply With Quote
Old 10-19-2013, 05:00 PM   #60
cyberlando
My Ride: 2002 M3
Eonon D5150 Install
Anyone know how good the RCA outputs on this unit is? I have a aftermarket component setup front and rear.....with an aftermarket Amplier
The info I need is what is the voltage rating for the head unit as far as RCA output
Engine:
[] Euro Headers [] Euro Cats [] OEM Section 2 AR20[] B&B Exhaust [] AFE Stage 2
Interior:
[] Led Interior [] DICE Module [] Auxilary 3.5 jack [] 4 channel Amp with component speakers.....and more
Suspension/Handling:
[] KW V3 [] Eibach F&R Sways [] Vibratechnics Tranny mount [] UUC RTAB
[] Vibratechnics Motor Mount [] SSBL [] Turner Camber Plates
[] 90A Akg Subframe Bushings [] Akg Differential Bushings [] Subframe Renforcement
cyberlando is offline   Reply With Quote
backup camera, bluetooth, business unit, navigation
