Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 244 votes, 5.00 average. Display Modes
Old 10-19-2013, 08:52 PM   #61
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Originally Posted by wicked_ink View Post
Thanks for puting this together WOLFN8TR! Great job!
Quick question, is there a 12HR mode for the clock or is it just 24HR mode?
Thanks,
Mike
Welcome...The 12 Hour clock works great if you have the correct time zone set with the GPS sync turned ON.
Originally Posted by therealet23 View Post
Yes in the settings...
The clock is kind of weird as I can never get it to be correct when it is synced to the GPS...
Originally Posted by Mr. Danutz View Post
Hello,
My name is Dan, and I'm from Romania. First of all, i want to appologise my english.
@WOLFN8TR - your informations about the product and the instalation are very great, and i want to thank you very much fort that. Monday arrives my D5150 and your tips are going to be very useful.
Welcome Dan! Glad to hear this is useful to ya. Good luck with the install!
Build Thread - S54 Vanos Thread
TTFS Engine/SMG Tune - SGT Headers/Sect 1/SCZA - Evolve Eventuri - Sprint Booster V2
UltraGauge - Orion V4's - CF Lip/Console/Diffuser - VIS XTS CF Hood - CSL Trunk - Valentine One - Turner 15F/12R Spacers
WOLFN8TR is offline   Reply With Quote
Old 10-20-2013, 11:27 AM   #62
esberelias
My Ride: '03 325i
awesome write up man!
My question to you is, when using the navi and switch back and forth between navi and radio interface, have you ever encountered freezing problems??? I've tried both 2.0 and 2.4 and they both freeze up on me I have to reset the deck and its annoying because I loose all my settings
Just downloaded igo 8 yesterday and going to test that today see how it holds up
Check out my ride
esberelias is offline   Reply With Quote
Old 10-20-2013, 02:26 PM   #63
cyberlando
My Ride: 2002 M3
Originally Posted by cyberlando View Post
Anyone know how good the RCA outputs on this unit is? I have a aftermarket component setup front and rear.....with an aftermarket Amplier
The info I need is what is the voltage rating for the head unit as far as RCA output
Can anyone answer my question?
Engine:
[] Euro Headers [] Euro Cats [] OEM Section 2 AR20[] B&B Exhaust [] AFE Stage 2
Interior:
[] Led Interior [] DICE Module [] Auxilary 3.5 jack [] 4 channel Amp with component speakers.....and more
Suspension/Handling:
[] KW V3 [] Eibach F&R Sways [] Vibratechnics Tranny mount [] UUC RTAB
[] Vibratechnics Motor Mount [] SSBL [] Turner Camber Plates
[] 90A Akg Subframe Bushings [] Akg Differential Bushings [] Subframe Renforcement
cyberlando is offline   Reply With Quote
Old 10-21-2013, 03:27 PM   #64
Melbs5150
My Ride: 02 330i
This thread is extremely insightful! Thank you.
Melbs5150 is offline   Reply With Quote
Old 10-21-2013, 04:49 PM   #65
shingo43
My Ride: 04 325ci
Just got my eonon and tried to install it. I have some questions:
1. how do you relocate the AC panel? I dont want to buy a relocation kit but it won't sit tight there, what do I need to do?
2. my unit came with 90 degree ipod wire and longer rca wires, however I still cannot make it sit perfectly flush, the left side is out a bit, is it normal?
3. My unit has a background noise, how do I fix it?
4. How do I make it learn the steering wheel buttons? I need to make the "call" button work.
5. I cannot find where to download the gps and map, can anyone please pm me?
Thanks a lot
shingo43 is offline   Reply With Quote
Old 10-21-2013, 05:03 PM   #66
Linx
My Ride: '02 BMW 325iT
1) Mine fit pretty tight without the kit. But in the past on the Enco thread I remember someone wrapped electric tape around the whole unit and made it sit pretty tight. As long as you do a clean job it should look ok
2) you have to trim around the antenna as well. Read WOLFN8TR install. It's in his signature
3)did you glue the rubber caps on the rca's on the back of the unit? That might be your problem or check anything lose
4)though it's there but you can't map the buttons. But I did find out if you're on the Bluetooth screen and Press the call button it will call last number dialed. Other then that it changes the EQ.
Linx is offline   Reply With Quote
Old 10-21-2013, 05:33 PM   #67
sjcbob
My Ride: 325iC
Great thread. FedEx just dropped off my unit today so I will be busy this weekend...
The packaging the unit came in was phenomenal. Well wrapped for the rigors of international shipping.
sjcbob is offline   Reply With Quote
Old 10-21-2013, 05:36 PM   #68
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Thanks...Ya my 5150 does freeze occasionally when switching, I have noticed it doesn't seem to do it as much if you take your time when switching between Nav, Radio and iPod etc.
How do you like Igo 8?
Not many people have used these units with amps from what I've seen. I will keep an eye out and let you know if I see anything regarding this.
Welcome...
Thanks a lot
(1) From what I've read guys are wrapping electrical tape around the AC control panel to get it to fit tight.
(2) Interesting...Can you post some pictures of the 90 degree iPod cable and RCA wires. How long are they? The Antenna cable is more than likely what is causing the unit to stick out on the left side. You can either trim the stock Eonon one or get the one I listed on the first page. That one is way more flexible when trimmed.
(3) Not sure if anyone has addressed this issue yet.
(4) I don't think this works with the Can Bus V2. I think it did with the V1 but you have to deal with the random inputs at start up.
(5) Not sure....Anyone???
Thanks...Yes it's packed very well.
Let us know if you have these features:
- Orange LED Color
- 90 Degree iPod cable
- Longer RCA wires
-Software Updates-
Originally Posted by EononCarDVD View Post
It can restore and update the software, so that the system will more stable and run more faster, but it is not for upgrading Orange LED button color, since it also related to hardware.
Old 10-21-2013, 10:48 PM   #69
sjcbob
My Ride: 325iC
Okay, I have run into a snag here. For the life of me, I cant get the center vents out. I shoved two credit cars to the top corners, so pressed in those clips, but the bottom is not budging and I am afraid that I'm going to pull the grill covers off without removing the whole unit. Any tips to the bottom clips to get the thing off?
Old 10-21-2013, 10:59 PM   #70
Linx
Sometimes it's hard to remove if it's been there a long time and hasn't been removed before. Slide the cards back n forth around the area of the clips and pull on the vents with a gentle pressure. My vents came out easy but I had a real hard time getting my HVAC out.
Old 10-21-2013, 11:10 PM   #71
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
When you slide the cards in the top two sides pull the vent forward. Now using a plastic or wood pry bar pop the bottom up and pull at the same time. If it's never been out before it's a Beouch. If you can hold the top from popping back in remove those two cards and then work on the bottom, that will make it not so tight. Mine was so tight I thought it was going to break and then it popped out.
Take a look at the pics where the two large clips are on the vent, two on top and two underneath.
TOP
BOTTOM
Old 10-21-2013, 11:15 PM   #72
shingo43
My Ride: 04 325ci
how do you guys adjust the gps volume? I can barely hear any voice prompt when music is on.
I already tried with mix on or off.
Old 10-21-2013, 11:17 PM   #73
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Mix and #8. Also there is a Volume control in the Nav settings.
Old 10-21-2013, 11:40 PM   #74
sjcbob
My Ride: 325iC
Thanks! I went back and decided to just brute force it. I wound up successfully removing the vent unit, but I tore the front cover off slightly and the slats started going all crooked.
I pushed a bit from the back to get the vent out. The slats in the vent became all slanted as a result, so I wound up removing the cable and bringing it inside the house to work on it.
Luckily, the cover didn't break off all the way, I was able to reseat the vents into their little pegs and pop the vent back on. woot.
Will hopefully finish the rest tomorrow.
I've attached some pics as well. Red circle is where you can see the cover of the vent snapped off. Luckily I was able to snap it back in.
ID:	531754   Click image for larger version
ID:	531755   Click image for larger version
ID:	531756   Click image for larger version
Old 10-22-2013, 12:22 AM   #75
shingo43
My Ride: 04 325ci
already maximized the volume in gps, still very low
Old 10-22-2013, 01:39 AM   #76
esberelias
My Ride: '03 325i
Had a 5 hour trip today and used igo 8... Didn't freeze on me once It's a bit different (I do like primo better) but I got used to Igo 8 and definitely sticking with it!
People are inboxing me asking me about Igo 8..... Google is your friend
Check out my ride
Old 10-22-2013, 05:16 AM   #77
Mr. Danutz
My Ride: BMW E46
Eonon D5150 Install
@linx can you show us a picture of the ac to see how it fits? Thanks
Mr. Danutz is offline   Reply With Quote
Old 10-22-2013, 11:24 AM   #78
sjcbob
My Ride: 325iC
Whoa, no USB in back
SO I reread the original install instructions at the start of the thread here. I realized that I dont have a USB connection in the back! Here is a picture of the entire set of wires coming out of the back of the unit. Mostly RCA plugs except for TPMS.
What gives? Anyone else missing this?
Old 10-22-2013, 11:29 AM   #79
Linx
It'll have to wait until later tonight. I'm at work and take the train in so I'm nowhere near my car. Unless you can call my boss for me and make up an excuse for me to leave early. Then I'll get right on it. But if not, then I'll post a pic later tonight.
Old 10-22-2013, 11:52 AM   #80
therealet23
My Ride: BMW M3
I def have one in the back of mine....
therealet23 is offline   Reply With Quote
backup camera, bluetooth, business unit, navigation
