Old 11-14-2013, 03:59 PM   #41
m3sc
My Ride: 06 TurboM3,06 SC C55
Originally Posted by Eric W View Post
Any updates? good or bad,................following this turbo kit development closely.
It looks like the stalling issue with the car had to do with an air leak in one of the couplers during installation.
It may be just the air-leak and not the kit or tuning that is causing the stalling issues on my car.
The car has the new turbo in it and clutch/flywheel installed.
m3sc is offline   Reply With Quote
Old 11-14-2013, 04:02 PM   #42
m3sc
Mike discovered an air-leak in one of the couplers which may contribute to the stalling issues with this car.
It may not be the tune or the kit that was the source of problems but a minor installation oversight.
So far, they have installed the upgraded turbo and clutch/flywheel.
Next step is to optimize the exhaust system and install the coilovers and sway bars.
Old 11-24-2013, 04:15 AM   #43
asirvr4
My Ride: Z4 M Coupe
Any plans for Z4M?
asirvr4 is offline   Reply With Quote
Old 11-24-2013, 02:03 PM   #44
mike@maximumpsi
My Ride: 02M3T
We have a customer from PA that is supposed to be bringing us a z4m. We are looking into using an e46m ecu and engine harness.
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 11-25-2013, 12:16 AM   #45
asirvr4
My Ride: Z4 M Coupe
interesting.. but what a shame to not do the MSS70.. its a very advanced ECU and might me better than MSS54.. it has Alpha-N as well..
try it while you have the car at least?
Old 11-25-2013, 07:41 AM   #46
NickG
My Ride: 2011 BMW 550i M-Spor
I wouldn't say the MSS70 is better than the MSS54. Newer yes, but not necessarily better. The problem with MSS70 is that its internal variables lack the headroom required to support the amount of airflow an engine with a turbo kit consumes. This means either an in-depth disassembly and rewrite of the OS (costs too much money for the project) or a 'fudge' in the tune to make it work in a half-ass manner (not my style so it isn't going to happen).
Alpha-N plays ZERO role in this, but the MSS54 also has that capability.
Nick
For Sale: 2005 BMW 330i ZHP with Technique Tuning Stage1 Turbo Kit
NickG is offline   Reply With Quote
Old 11-25-2013, 02:36 PM   #47
BDUB328I
My Ride: bmw 328i S54 sedan (
The godfather has spoken
BDUB328I is offline   Reply With Quote
Old 11-25-2013, 09:26 PM   #48
mdrobnak
My Ride: 04 330i SMG TT STG1
Aside from the cluster.... that the software in the MS45 is, it did make me wonder why they didn't just go with that hardware instead of yet-another-DME variant with the MSS70. I assume the reason is for tighter emissions output for the update...unless it was to integrate with the rest of the vehicle's electronics better. What are your thoughts on the reasoning, Nick?
-Matt
mdrobnak is offline   Reply With Quote
Old 12-03-2013, 08:44 PM   #49
m3sc
I hope the jerkiness of the UUC feramic clutch on my SMG M3 Vert has nothing to do with the TCU needing a tweak too. Must go back to a UUC organic clutch now.
Old 12-04-2013, 06:33 AM   #50
mike@maximumpsi
My Ride: 02M3T
I don't know why I read each of your posts as a jab. The Uuc feramic worked exactly as it was supposed to at wot, and engaged smoothly from a stop with light throttle. If you gave it moderate throttle the car would shudder a bit until the clutch fully engaged. I ordered a set off organic discs because I don't think you will be happy with the clutch engagement in traffic and I am swapping everything out for you since it was my choice to try the twin feramic for your possible higher power goals.
Old 12-04-2013, 10:24 AM   #51
BrianSpilner
My Ride: Max PSI Stage 2
Even the HPF (Southbend) Stage 2 SMG Feramic Clutch has a little bit of jerkiness to it starting in 1st or 2nd gear from a stop; you get used to it once you learn the precise throttle position to prevent that.
Follow My Builds: Max PSI Stage 2 E46 M3 Turbo Build | 1972 2002 Restomod Build
2004 BMW E46 ///M3 | Maximum PSI Stage 2 Turbo | SMGII | Non-Catted | 711rwhp | 578rwtq
BrianSpilner is offline   Reply With Quote
Old 12-04-2013, 08:05 PM   #52
mike@maximumpsi
My Ride: 02M3T
Agreed.
Old 12-04-2013, 08:11 PM   #53
m3sc
In that case I apologize if this is normal for a feramic clutch.
Old 12-05-2013, 08:52 AM   #54
mike@maximumpsi
My Ride: 02M3T
No problem, just making sure everyone knows we are on the same team.
Old 12-11-2013, 09:39 AM   #55
Hobbit382
My Ride: 99-328i 00-323i
any updates on the e85 tune?
Hobbit382 is offline   Reply With Quote
Old 04-18-2014, 11:51 PM   #56
Riotch671
My Ride: 2002 e46 BMW M3
+1!
Riotch671 is offline   Reply With Quote
Old 04-27-2014, 09:23 AM   #57
milKt
My Ride: air/fire
Sheesh....
How much more power is needed? lol
On a conservative tune, reasonable kit price and tech support to boot,
they've offered a 10 second car upgrade.
I know...I know...
there's never enough. I know the illness.
milKt is offline   Reply With Quote
