E46 Xi Forum
Old 09-07-2013, 09:19 AM   #21
Arnezie
My Ride: 04 325XI
Originally Posted by biglittledog View Post
2 expansion tanks: yeah, that's a crappy design and something they should have fix...plus the first may have frozen and weakened when the PO didn't have windshield antifreeze in the tank.
Washer pump replaced: I would almost guarantee that someone was cheap and put water or water mix instead of windshield antifreeze into the tank to save 2 bucks. The water freezes and either breaks off the plastic impeller or burns out the motor when it can't turn. I've seen this on lots of cars. Operator error and one of my pet peeves. Buy a 40k+ car and then too cheap or lazy to do the most simple maintenance. Not necessarily you that did it wrong.
What are you talking about antifreeze and windshield washer fluid are 2 different things
Arnezie is offline   Reply With Quote
Old 09-07-2013, 09:22 AM   #22
biglittledog
My Ride: 2002 325xiT
I think you know... winter windshield fluid. Obviously not engine coolant. I've edited the original post so you won't be confused anymore.
Steve in the foothills of the Rockies
2002 325xiT (have 2)
1967 Jaguar 420G
1945 Dodge WC52 Weapons Carrier (snowplow now)
2003 Harley Dyna Super Glide
1989 Honda XR600r
1968 BSA Shooting Star
biglittledog is offline   Reply With Quote
Old 09-07-2013, 09:43 AM   #23
Arnezie
My Ride: 04 325XI
I wasn't confused , I think you were
Old 09-07-2013, 09:57 AM   #24
CylonRed
My Ride: '01 E46 330i sport
There is zero reasons a 2003 would need a new engine except for abuse - and a lot of it either from you, the previous owner, or a combination. 2 alternators - not unheard of. I replaced an alternator in my Civic and it failed within a week. The third one was fine. The first one lasted over 180K miles. Your other items that you replaced 2 times - no - none should have needed them replaced 2 times in less than 200K miles. There are quality parts out there - they are not hard to find (Stewart water pumps for one).
My 2001 still have the original clutch/flywheel (as far as can be determined), entire suspension is original, alternator, springs, one control arm has been replaced the rest are original, and the bushings are original. This is with 175K miles on the car and I am the 3rd owner. First owner put all of the miles on the car.
CylonRed is offline   Reply With Quote
Old 09-07-2013, 01:22 PM   #25
adrian8507
My Ride: E46 325xi 2002
Re: I hate BMW's
I think you bought a abused E46 and previous person didn't do any maintenence on that car so you had to pay for his actions.
adrian8507 is offline   Reply With Quote
Old 09-07-2013, 01:59 PM   #26
White_Knuckles
My Ride: 2003 325xi
I'm not gonna hate on BMW's 'cause some owner claims they're potentially a part eatin', money pit. The average owner experience, in terms of maintenance frustration, would probably check the "acceptable" box. Owning many cars for many years allows me to state, if proper maintenance is performed, with quality parts, these clearly can be ran into high mileage numbers without excessive expenses such as, engines, transmissions, transfer cases or thousand dollar electronic modules. Stuff that breaks (wear items like belts) breaks on all cars. So what's all the crying about?
This forum will save you big bucks with less mistakes! Example, before plunging into a cooling system refresh, I read 20 threads here. Locked in, I ordered a BMW expansion tank, Stewart pump, OEM supplier hoses belts and what-nots. I did not order the bundled "kit" from the cheaper supplier because I read about failures and fitment problems involved. With clear technique documented by others, the installation went flawlessly with no issues for thousands of miles later. Axles, boots and bears - oh my! Get over it and pay attention to replacement parts. I had a couple boot clamp leaks where I re-booted the factory axles at 60K. A boot ripped a couple years later eating the CV where the Independent shop recommended new Empi Axles. The shop never gets recalls and offered a three year warranty parts and labor. I had both sides replaced. Three years, no worries, and way less expensive than the German flavors. So its not always factory parts only as the purists believe.
It's all about research and time you're willing to invest to take care of your car. For the "I never want to do anything" type of owner, getcha a Toyota and go away please.
Old 11-25-2013, 11:12 PM   #27
sammy2303
My Ride: 325 xi
E46 factory rear suspension is sub-par for any car. GM AS5 390R transmissions are just that- GM made. They have seal issue.
Front end suspension requires preventive maintenance on all the rubber/vinyl parts- spray them with Armor Oil if you can.
This will buy you an additional 20K miles but eventually they fail. Control and stabilizer bushings fail prematurely.
German engineering is sound but economics drive sub-par components, to drive retail lower, to promote sales,
at the expense of the user. Sounds like GM.
Question: Has there ever ben a study to see what car will run the longest without any repair? I'd guess the 1975 Toyota Corona.
sammy2303 is offline   Reply With Quote
Old 11-26-2013, 10:10 AM   #28
SamDoe1
My Ride: 4cyl of fury
lolwut?
Armorall (I'm guessing that's what you meant by armor oil?) is notorious for drying out plastic parts and making them sticky and bad. No wonder you have issues with stuff only lasting 20k miles.
