Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 09-19-2013, 11:40 PM   #41
Marshmallow
My Ride: Ehhh...
Originally Posted by fin1211 View Post
I'm not too familiar with how stick shifts should feel, as this is essentially the first one I've driven, but should I be worried if shift movements aren't too smooth? Especially into second.
What specifically gives you cause for concern? Is it you or the car?
Marshmallow is offline   Reply With Quote
Old 09-20-2013, 01:35 AM   #42
Vince504
My Ride: has 3L and 3 pedals
Originally Posted by foo-fighter69 View Post
I've only driven my car around 3,500 miles or so sense I bought it only,had it about half year. The wrenching I've done so far. Is just the regular oil change, I had to change a brake line hose as well. How does your shifter lever feel my was totally worn out and swiggly even in gear and when I shifted I heard a loud thud noise. I fixed that by getting a new guibo and shifter bushings. The stuff I should do and would recommend. Is possibly the vanos. I don't think mine is working with my high mileage. Yours might be good though I mean it was owned by a tec. I want do the cooling system saving my tips up right now. Dude why you gotta be all the way in Chicago I need a bro to wrench with. I use to have a e46 bro but he went off to college. Now I wrench with my e39 bro.
Vince504 is offline   Reply With Quote
Old 09-20-2013, 07:30 AM   #43
fin1211
My Ride: Sienna Red 330ci
Re: Just purchased '01 330ci stick, sienna red!
Not the actual shift itself that I'm worried about, but the shifting motion from 1st to 2nd or from 3rd to 2nd.
Not sure how this could be driver induced.
Sent from my HTC One using BimmerApp mobile app
A driving POS is better than a beauty stuck idle in your garage. A beauty stuck on your shifter is entirely different.
If you want to have sex, do your belts before your lip.
^^my beautiful car^^ <3
fin1211 is offline   Reply With Quote
Old 10-04-2013, 10:29 AM   #44
Interlagos
My Ride: 2006 E46 M3
The wheels look so much better now.
Interlagos is offline   Reply With Quote
Old 10-04-2013, 04:07 PM   #45
fin1211
Wutchu talking about? They're still black.
Old 12-29-2013, 05:06 PM   #46
fin1211
Hmm... So I've got a question for you guys. Weird clunk coming from driver side rear, right after I switch back to stock suspension, and get it aligned. Also, since having the car, it is sometimes difficult to engage first gear, in which case I will simply roll it a bit in second and then it will shift into first just fine. Both of these things point to possible subframe damage, no?
Display Modes
