Old 09-04-2013, 01:02 AM   #1
sylvea
My Ride: 2003 325i
Pre-cat O2 Sensor Problem
A year ago I had about 90k on my 2003 325i when I threw a (IIRC) two O2 sensor faults. I replaced all four O2 sensors since they were near their lifetime and didn't feel like going through the routine 2 months later when/if the other 2 failed.
Now 18 months later, I threw a 20c2973 "PreCat O2 sensor/wires Bank 1" fault on my Peake scanner. These have a 1 year warranty so it would be out of my own pocket. Before I lay out $161 for a new sensor, is there any reason why I would throw this code if it wasn't the sensor that failed?
I do have a California smog/emissions inspection coming due and figured I'd take care of this before I take it in even though I understand it is the post-cat O2 sensors that control emissions.
Thanks in advance:
GS
sylvea is offline   Reply With Quote
Old 09-04-2013, 02:03 AM   #2
e4603
My Ride: #3 bus
Bosch O2 sensor at Amazon for about $50.
e4603 is offline   Reply With Quote
Old 09-04-2013, 02:08 AM   #3
sylvea
My Ride: 2003 325i
Can you post the link?
This one is $173 including shipping.
http://www.amazon.com/03-06-Oxygen-S...1+78+7+523+434
~GS
Old 09-05-2013, 01:19 AM   #4
Mrpoman
My Ride: 04 330cic
I just bought one and installed for the rear pre cat for an 04 330. If you search for 17216 (rear, bank 2) on amazon you can find the one fulfilled by amazon for about $90. I think the front (bank 1) is 17215.
Mrpoman is offline   Reply With Quote
Old 09-10-2013, 07:02 PM   #5
comova
My Ride: Silver 325Cic
I literally just (AM) bought the last $50 Amazon O2 sensor from 'Delaware'. I email them to ask if they were getting more (because I need 2) ...Bruce only said "out of stock"
I hit AutohausAZ for the second one, It was 20 bucks more but shipping was free.
"The problem with the designated driver program, it's not a desirable job, but if you ever get sucked into doing it, have fun with it. At the end of the night, drop them off at the wrong house." -Jeff Foxworthy
comova is offline   Reply With Quote
Old 09-11-2013, 12:07 AM   #6
e4603
My Ride: #3 bus
Sorry for the late reply; just got back from Maui. See if this one (bosch 13477) fits your car:
http://www.amazon.com/Bosch-13477-Ox...ds=bosch+13477
http://www.boschautoparts.com/Vehicl...artFinder.aspx
Old 10-13-2013, 02:54 AM   #7
sylvea
My Ride: 2003 325i
Uggg. Replaced the O2 sensor. $90 (thanks for the links). Drove the car 200 miles. No codes. I'm happy. Drove another 100 miles and it threw the 20c2973 code (PreCat O2 Sensor Wires/Lines, Bank 1) again. Any suggestions on what's causing this?
Thanks in advance!
Old 10-28-2013, 07:35 PM   #8
e4603
My Ride: #3 bus
Did you try swapping the 2 sensors and see if the problem follows the sensor?
Remove plastic engine cover and check if the sensor wires are good.
Maybe use this type of o2 sensor socket
http://www.pelicanparts.com/BMW/tech...mall/pic05.jpg
instead of this
http://www.availabledark.com/images/bmw/o2diy01.jpg
so you don't put pressure on the wiring during install.
