Sponsored by BAVSOUND
Old 09-04-2013, 08:00 PM   #1
GeigerBMW
My Ride: 2003 330Ci 5 speed
Help needed - stock Business CDand Amp, new woofers but passenger side is distorted
Our 99 323 sedan showed all four mid/woofer in the rear deck and in the front doors were needing replaced shortly after we bought it. The foam surrounding the cones had crumbled to dust. I made use of the speaker baskets from the old units and installed four new inexpensive 4 ohm 6.5" Sonys:
http://www.bestbuy.com/site/Sony---6...&skuId=7780102
I spliced factory brown wires to negative on speaker terminals. I kept the original 2 ohm door tweeters in place.
When I turn it on, the passenger side speaker is VERY distorted and the passenger front is also somewhat distorted and quieter. The driver's side units seem fine. It seems to me like the amp is blown and I will tear into the trunk for that this weekend. I will first swap speakers side-to-side to see if the issue follows the speakers or the wires, but I strongly suspect the right channel on the amp is blown.
Does anyone know how to properly test the amp's channels? Is it a line-level amp? My old e30 had a speaker level amp and I would assume BMW would have changed over by 99. Is there a way to test the head unit's output going into the amp to rule it out? This is a non-HK system.
I did not want to remove the stock Business CD unit as I prefer things to look stock. So if the amp is the offending unit, is a used factory amp the best option? Any other ideas what could be culprit or troubleshooting approaches would be greatly appreciated.
Thanks in advance,
Geiger
GeigerBMW is offline   Reply With Quote
Old 09-06-2013, 09:10 AM   #2
GeigerBMW
^^ Bump ^^
Old 09-07-2013, 07:38 PM   #3
GeigerBMW
^ Bump ^
Old 09-08-2013, 11:08 AM   #4
markusmarkus
My Ride: 2001 330Ci
The oem amp is a 4 channel in and a 10 channel out unit. It has built in crossovers and 5 dual channel amplifier MOSFET (a semi-conductor technology) chips.
I would double check the installation of the new speakers. Testing of the amp would require an oscilloscope (an electronic instrument that produces an instantaneous trace on the screen of a cathode-ray tube corresponding to oscillations of voltage and current).
If the installation is ok I'd see if there's an oem amp for sale on this website. It should be a cheap buy.
amplifier, blown, business cd, radio, speaker
