Old 09-06-2013, 11:03 AM   #1
thecarguy
My Ride: ZHP Sedan
Red face G.A.S. DISA rebuild kit question
I searched and read countless threads on the rebuild kit and noticed most say they had play and slop where the lever gear meets the flapper. I have no play in that area. The only play i have (where the noise is coming from) is between the top pin and the housing. When I shake unit or move flapper that is where the noise comes from.
In looking at the GAS rebuild kit, it seems that if I assume the top of the titanium screw is the same diameter as the stock pin, it will still rattle. My reasoning is that it is the hole that the pin and would be titanium screw top would reside in is no slightly larger due to wear so it would be the same for both.
Correct?
thecarguy is offline   Reply With Quote
Old 09-06-2013, 07:02 PM   #2
thecarguy
My Ride: ZHP Sedan
Lightbulb
Maybe a video will help. This is the ONLY play I have...
