E46 Xi Forum
Old 09-06-2013, 01:49 PM   #1
Sgtbean
My Ride: 03 325xi
Clunk in the Trunk hehe
So I've had a clunk in my trunk area on both sides going over bumps at slower speeds. I think I may have found the culprit. Click image for larger version
This is the driver side end link in the rear. The passenger looks just as bad. My question is can I replace it with a stock e46 end link or would I have to go with a hotchkis end link since that is what the sway bar is. Also with the brackets that hold it to the frame would those be stock as well since I can't seem to find them separate from a whole hotchkis sway kit. Thanks!
Sgtbean is offline   Reply With Quote
Old 09-06-2013, 02:21 PM   #2
SamDoe1
My Ride: 4cyl of fury
You can replace with stock end link. The bracket will just come out of there or you can buy a new one too. You will have to drop the whole rear sway bar out to get the bastard in as the bottom bushing is pressed on...ask me how I know.
Old 12-04-2014, 02:47 PM   #3
Sgtbean
My Ride: 03 325xi
Clunk has been eliminated. Just wanted to bump this and say that 5h3 culprit of my knocking over bumps was the rtabs. I ended up changing the shock mounts and that didn't solve it so finally did the rtabs and helleluah the noises have ceased. Can't be more over the moon. Thanks for the help!!!
Old 12-04-2014, 04:06 PM   #4
TR4G-
My Ride: '01 325xi, '90 325iC
ugh, ok I was starting to this maybe my issue was the endlinks as well! What exactly did this clunk sound like and when did it occur? I have one that is super rare, only during specific motions and I can't think of anything other than it being my rear strut itself
TR4G- is offline   Reply With Quote
Old 12-04-2014, 04:15 PM   #5
Sgtbean
My Ride: 03 325xi
Whenever the suspension flexed left or right. Specifically over smaller bumps at slower speeds. Yours could be the shock mounts. Or if you haven't or don't know if your rtabs have ever been done it's a good idea to do them. Mine looked ok before pulling, but when they were pulled they looked terrible and were falling apart.
Old 12-04-2014, 06:12 PM   #6
TR4G-
indeed, thanks for response. I've done RTABs recently as well as my shock mounts and struts and coils
