Sponsored by BAVSOUND
Old 09-07-2013, 01:34 PM   #1
hound4
My Ride: 2002 325xi 5spd
Bluetooth install with after market amp
Hi guys, I'm really stuck. I have the OE head unit and an aftermarket amp installed. I hard wired a Parrot CK3100 following excellent PIN finding instructions at link below. So head unit displays "PHONE", mutes radio, etc. But since I have an aftermarket amp, and the Parrot has a small amplifier built in, I ran a line directly to the front right speaker (Parrot is too loud if run through amp). Everything works, except the Parrot sound is SUPER shrill and so distorted.
My question is whether some signal is still being sent back to the amp, even though I spliced in AFTER the amp? Please help! I must be missing some basic part I just don't know what....
http://www.e46fanatics.com/forum/sho...d.php?t=586800
hound4 is offline   Reply With Quote
Old 09-07-2013, 01:59 PM   #2
hound4
Do I need a relay, in other words when I tell OE head unit to mute I use this signal to tell amp to turn off? Even though I've muted amp, is it still outputting a ton of sound which then totally distorts the direct line I have from parrot to speaker?
Old 09-08-2013, 10:08 AM   #3
hound4
Problem solved: I had everything wired correctly, just didn't realize that you need to cut the factor line to the single speaker to which I directly wired the Parrot. I basically had crossed the line from the amp and Parrot which is a definite no no (lucky I didn't burn out my amp). If anyone has problems in the future please PM me and I will try to help. If anyone wants a DIY write up on this let me know...
Old 09-08-2013, 11:28 AM   #4
hound4
I created a DIY for what I did, available here:
http://forum.e46fanatics.com/showthr...1#post15693501
Hope this is helpful to others!
