Sponsored by BAVSOUND
Old 09-08-2013, 04:45 PM   #1
straight_beamin
My Ride: 2000 bmw 323i
aftermarket radio harness, car not starting HELP
Ok, so i have a kenwood deck hooked up to a 4 channel amp everything working fine except radio reception sucked. Pulled out unit to find the antenna unplugged. plugged it back in and realized the harness at the kenwood deck harness had all the wires cut off (never realized this because the speakers run off the rca preouts anyways) leaving exposed wires. it proceeded to spark. unplug battery rig it all up and it works ok. go to start the car this morning and it doesnt crank. pull unit and it starts right up... plug it back in and it wont start.. unplug and it starts again..... oh and with it plugged in the cluster just clicks and doesnt work as well
i ordered a new kenwood 16pin harness... do you think that is the problem? maybe a fuse blew?
appreciate any help
straight_beamin is online now   Reply With Quote
Old 09-09-2013, 07:31 AM   #2
markusmarkus
My Ride: 2001 330Ci
Not a fuse problem as the car starts when the head unit is unplugged. I suspect the head unit is reducing the voltage on the "always on" wire thereby causing an inadequate voltage condition.
Old 09-09-2013, 09:01 AM   #3
straight_beamin
Re: aftermarket radio harness, car not starting HELP
So a new harness should fix it up no?
Sent from my GT-S7560M using BimmerApp mobile app
Old 09-09-2013, 12:04 PM   #4
straight_beamin
By the way thanks for help
Old 09-11-2013, 10:08 AM   #5
straight_beamin
Car did it again but with radio unplugged. It wouldnt start this morning it just clicked. Unplugged battery and plugged back in then it started right up... wires shorting behind radio maybe?
