E46 Xi Forum
Old 09-08-2013, 07:38 PM   #1
insufferable
My Ride: 2001 330xi
Motor mounts
Hey there. I need to replace both left and right motor mounts on my 01 330xi. My parts guy says he has no listing for the 330xi but has a listing for the 330i. Will one interchange with the other?
Thanks for the help.
insufferable is offline   Reply With Quote
Old 09-08-2013, 07:58 PM   #2
powbmps
My Ride: 2002 330CiC
I believe the xi uses the same version as the M3, which is a little more rugged than the regular i.
powbmps is online now   Reply With Quote
Old 09-08-2013, 08:21 PM   #3
e46jki44
My Ride: e46 325i sedan
Re: Motor mounts
Im pretty sure the xi motor mounts arr completely different from any other e46 mounts.
Sent from my SPH-D710 using BimmerApp mobile app
e46jki44 is offline   Reply With Quote
Old 09-08-2013, 09:15 PM   #4
White_Knuckles
My Ride: 2003 325xi
Try PelicanParts.com and RealOEM.com and you'll find the proper part numbers. Your parts guy is kinda lazy.
Old 09-08-2013, 09:40 PM   #5
Omegahpr
My Ride: 2001 330Xi
I recently replaced both motor mounts in my 2001 330xi. Here are the part numbers:
- 22116750862: passenger side
- 11812283798: drivers side
The passenger side mount is unique to the xi while the drivers side is the same as the M3. You can reference Realoem.com for your parts as well.
Good luck!
Omegahpr is offline   Reply With Quote
Old 09-09-2013, 01:39 PM   #6
insufferable
My Ride: 2001 330xi
Yeah, he's a little lazy but the cost of his parts are about 1/3 that of anyone else around here. He's off 6 nations indian reserve and brings his parts in at U.S. prices and no tax. It's worth doing the research on my own.
If it were a chev or ford it wouldn't be a problem at all. He doesn't do much with European Imports.
Thanks for the info.
Cheers
Old 09-09-2013, 02:22 PM   #7
Kubica
My Ride: 2003 325xi
Most can get away with just the passenger side mount on an xi.
Old 09-11-2013, 09:28 AM   #8
SilvaBimma
My Ride: 330Xi
Anyone run a different regular LEFT motor mount? Or is the standard OEM set the smartest way to go?
SilvaBimma is offline   Reply With Quote
Old 09-15-2013, 02:23 PM   #9
rawbspear
My Ride: 04' E46 XIT 5 speed
looks to me like a person could install one of these for the left in place of the standard M3 mount but not as stiff as the Group N mount:
http://store.bimmerworld.com/bimmerw...unts-p930.aspx
rawbspear is offline   Reply With Quote
