Sponsored by BAVSOUND
View Poll Results: Which sub setup do you think would work best for what I want
four 6" bazookas 0 0%
2 8" bazookas or slim subs(if they fit straight in" 0 0%
2 10" slim subs in a crazy custom enclosure 4 100.00%
Voters: 4. You may not vote on this poll
Old 10-16-2013, 10:45 AM   #41
limpiabota809
My Ride: 330 XI
Originally Posted by Bino5150 View Post
Yeah most likely. I'll probably knock out that center section and them mount the sub box back a couple inches
The diameter of the ski pass hole is a little more than 8 inches, you'll definitely have to mount the 12 inch back a bit...what sub are you thinking about?
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 10-16-2013, 02:53 PM   #42
M_South_Afrikanna
My Ride: e46 325i
anyone know where i could get my hands on a black rear seat back with the fold down arm rest. I need it for the install and I cant seem to find any
M_South_Afrikanna is offline   Reply With Quote
Old 10-16-2013, 04:59 PM   #43
Bino5150
My Ride: 99 323i
Yeah I intended on having it sit back a few inches anyway, even before I knew about the ski pass knock out. I'm running a Q Power 12". I'm going to build a wide thin box so it will clear my rear strut tower bar.
I thought about running one of the slim Pioneers, but I already have 2 Q Power 12's sitting there in the shop that were in the trunk of my Impala that I totalled. I was going to put them in the trunk of my '68, so I'll just need to get another one later on down the road.
Bino5150 is offline   Reply With Quote
Old 10-16-2013, 05:44 PM   #44
limpiabota809
My Ride: 330 XI
Cool, let me know if you need help
Old 10-16-2013, 06:39 PM   #45
TR4G-
My Ride: '01 325xi, '90 325iC
Ideas for in cabin sub-woofer for the sealed sedan
I had the same thoughts as you when looking for a sub system. The trunk subs are somewhat silly as our cars are designed to isolate noise from the trunk (sealed area plus sound deadening). I ended up dropping two 12s Into the rear deck because I enjoy projects
TR4G- is offline   Reply With Quote
Old 10-16-2013, 08:49 PM   #46
ultimatemj
My Ride: 04 E46 M3
Well, if you don't want to cut holes in the rear deck, then
How about building new trim panels for the rear quarters?!
If you only put 1 driver on each side, you could put the magnet inside
ultimatemj is offline   Reply With Quote
Old 10-16-2013, 08:59 PM   #47
asubimmer
My Ride: 99' e46 323i
That's not a sedan...
asubimmer is offline   Reply With Quote
Old 10-17-2013, 12:46 AM   #48
limpiabota809
My Ride: 330 XI
Doesn't seem practical and I see issues with it, for example if you try and run anything other than a shallow speaker/sub...if not then fiberglass work will have to be done and then things get complicated and pricey
Old 10-17-2013, 09:04 AM   #49
M_South_Afrikanna
My Ride: e46 325i
It does look cool though, same with the rear deck option.
Old 10-26-2013, 04:58 PM   #50
limpiabota809
My Ride: 330 XI
A little bit more fitting, but this 8 slams!!!
Old 10-28-2013, 06:55 PM   #51
M_South_Afrikanna
My Ride: e46 325i
new problem. I cant go punching the hole out the rear because I dont have the rear seat with the arm rest nor am I able to swap in one with it so.. any ideas.
Old 10-28-2013, 07:29 PM   #52
limpiabota809
My Ride: 330 XI
Something like this
Old 10-28-2013, 08:12 PM   #53
M_South_Afrikanna
My Ride: e46 325i
:/ was hoping to not cut the rear deck I guess I might have too. What if I just stuck A port through the seat? Like cut the foam out lace the leather and insert a port. you wouldnt even be able to tell its not supposed to be there. horrible idea but just shooting it out
Old 10-28-2013, 08:13 PM   #54
M_South_Afrikanna
My Ride: e46 325i
anything to open the air from the trunk into the cabin
Old 10-28-2013, 08:25 PM   #55
StereoInstaller1
My Ride: 4 door demo booth
The last E46 I did lacked the armrest as well. I really could not tell the difference with the seat in or out, it sounded the same.
StereoInstaller1 is offline   Reply With Quote
Old 10-28-2013, 08:38 PM   #56
Brevik
My Ride: Tiag M3
Damn this thread sucks. Op just put a sub in the trunk like a normal human and be done with it.
Brevik is offline   Reply With Quote
Old 10-28-2013, 08:39 PM   #57
M_South_Afrikanna
My Ride: e46 325i
was the sub sealed? I plan on doing a ported one and I thought the foam would be to insulating to allow the air into the cabin. hey if its not the Ill just do the punch out cut out a little foam just to give some space in front of it and then build my box
Old 10-28-2013, 08:44 PM   #58
M_South_Afrikanna
My Ride: e46 325i
Hey never ment it to be anything exciting i was looking for answers. and some people found use of it man. I would do that if (as stated earlier) the trunk wasnt sealed. I have already tried one in the trunk and honestly its louder outside the car and my trunk just rattles. hence the thread to work around it. dont want to help thats fine
Old 10-29-2013, 02:08 AM   #59
StereoInstaller1
Because it is inefficient, sounds horrid and makes your car rattle like a cheap Honda?
Old 10-29-2013, 03:36 AM   #60
NumbaOneNewb
My Ride: 2003 330CI Silver
The rear deck sounds interesting but that metal under the rear deck looks time consuming to cut
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
