E46 Xi Forum
Old 09-09-2013, 08:48 AM   #1
weezintrumpeteer
My Ride: Fit/Miata
Considering a 325xi Touring 5speed!
Hey Guys....first post here.
I've been looking for an e46 touring and happened upon this one
It's a 325xi Touring 5 speed with sport package (and some amazing looking wheels).
I haven't considered an "xi" BWM before, so I don't know much about them.
I'm going to head down to the dealer tonight to take a look. Anything in particular I should look out for?
Also, any specific "xi" problems that I should be aware of?
Thanks!
Patrick.
weezintrumpeteer is offline   Reply With Quote
Old 09-09-2013, 08:57 AM   #2
YaSureYouBetcha
My Ride: 2002 325xi
Sweet looking ride.
IMO, Xi's tend to be relatively robust as compared to their rwd counterparts from a drivetrain standpoint. However many of the common preventative maintenance items cross over, cooling system ( refresh every 80-90k miles), front CAB's, MAF, etc. there are a few good stickies on this site to read through as you move to purchase. Best thing to do is get a local Indy mechanic, who knows these cars, to give it a good look prior to closing the deal.
I love my Xi, although its in the sedan form. Better handling dynamics than any vehicle I've owned, and frankly the AWD out performs any of the trucks or SUVs I've had from the standpoint of remaining sure footed on our wonderful Minnesota winter roads.
Good Luck!
YaSureYouBetcha is offline   Reply With Quote
Old 09-09-2013, 10:09 AM   #3
weezintrumpeteer
My Ride: Fit/Miata
Originally Posted by YaSureYouBetcha View Post
Sweet looking ride.
Good Luck!
Thanks! That helps. I've gone through some of the threads here (like the high-mileage thread) and some of the repairs have me a bit worried. Not sure if they're xi specific though.
I'm coming from a Honda Fit, so I have to get ready for the BMW maintenance world
Old 09-09-2013, 10:32 AM   #4
YaSureYouBetcha
My Ride: 2002 325xi
The great part about the E46 is that they are mechanically well engineered, almost to the point of bring elegantly intuitive. So if you have some level of mechanical aptitude, they are really nice cars for a DIY guy. For instance, I consider myself very mechanical, the cooling system refresh took me just a little over 2 hours, then refilling and bleeding the system afterward, so all in maybe 4 hours. This job cost about 20% of what it would have at a shop, and was really very simple. But, at the end of the day, it's not a Honda, it's a performance car and requires some good TLC preventative work to keep it driving well. So just be sure you understand and are willing to keep the vehicle maintained or you might not be happy after 30 - 40k miles.
Again good luck!
Old 09-09-2013, 12:44 PM   #5
weezintrumpeteer
My Ride: Fit/Miata
Again good luck!
Thanks. Yeah, that's the way it seems. I am somewhat mechanical and can follow instructions very well, so I doubt I'd have a problem with most things.
Old 09-09-2013, 01:05 PM   #6
EDWAGON
My Ride: 2004 325xiT
Thanks!
Patrick.
Nice looking car almost a twin to mine. XI parts are usually little more especially around the front drivetrain area.
I have mine since 09 at 34 k now have 83k . Love it ,great car in the snow. Good luck!
EDWAGON is offline   Reply With Quote
Old 09-09-2013, 10:49 PM   #7
E46@46
My Ride: 2003 325xiT
I'm at 173k miles on my XI wagon. I've done all the work except an axle. Love the wagon and great in the snow especially with snow tires.. Still drives as good as new... Since all the PM work..,
E46@46 is offline   Reply With Quote
Old 09-10-2013, 12:42 AM   #8
autoAER
My Ride: 2005 325i 5MT
actually, IMO XI's have less problems than their RWD counterparts. XI's are built solidly and have extra reinforcements (occasionally in areas of high failure of the RWD cars). I've put about 20k on mine, and I've had less problems than both my last E46 (1999 328i), my dads car(s) (E46 330i), and after preventative maintenance, she has NEVER left me stranded and/or wanting a different car. truly a great car if you can keep up with it, and the AWD system is not as bad as some people make it out to be. I've not encountered a snowy/rainy road my XI couldnt handle. btw, I LOVE the touring in your photo, gorgeous car. Good luck with whatever car you buy
Past: 2006 330i, 2006 325i 6MT, 2003 325xi
Current: 2008 335i E90 N54, 2005 325i 5MT
autoAER is offline   Reply With Quote
Old 09-10-2013, 01:38 AM   #9
BosE46ton
My Ride: 2003 BWM 325xi
How'd this go?
If you haven't bought it yet, stuff to look for is true with any used car and any all wheel drive vehicle.
Eric the car guy is a pretty solid source (though he specializes honda) of general used car maintenance and how to inspect used cars.
http://m.youtube.com/user/EricTheCarGuy
General quick tips I can think of:
-Listen for loud differential whine.
-Look under the oil filler cap and at the dipstick. Anything that looks milky or different than light to dark oil means water/coolant is getting into the oil. Bad.
-These cars are a little heavier. Therefore I feel like mine has eaten rear springs maybe a little more often than other cars I've had. I have an 03 Sedan. I do live in the Northeast where the roads are garbage and I blame them more than the car.
-Dirty, but.. engine bay. Left side. Where the valve cover meets block. Check the Valve cover gasket. Check it at the rear of the engine near the firewall, on the back area. Easy to reach, not to see. Rub your fingers on the seam between VC and block and look for new/fresh or excessive oil.
-The tires should all be identical and have even tread wear. You need them at all the same rolling height.
-Feel the rotors. Smooth? Deep grooves?
-If you get the car, remove the rear springs and ship them to me.
Good luck
BosE46ton is offline   Reply With Quote
Old 09-10-2013, 08:28 AM   #10
weezintrumpeteer
My Ride: Fit/Miata
Thanks. When you say "all the work", what do you mean?
Old 09-10-2013, 08:30 AM   #11
weezintrumpeteer
My Ride: Fit/Miata
Interesting. I went though the "high mileage xi" thread and noticed that a lot of people were having the same problems (specific to the xi...front driveshafts, axels, cvs, etc).
Yeah, that particular touring is really gorgeous. I went in looking for a RWD car and then this one popped up. I can't decide what to do!
Old 09-10-2013, 08:32 AM   #12
weezintrumpeteer
My Ride: Fit/Miata
Originally Posted by BosE46ton View Post
How'd this go?
Good luck
Thanks for the information, I'll take a look at that.
One thing to note is that this particular car seems to be sitting low for an xi. I checked under the car and saw BLUE springs...I'm guessing that this means someone changed out the suspension. Hmmm.
Old 09-10-2013, 08:33 AM   #13
TArse
My Ride: 03 330xi, 87 325is
I want a touring so bad
TArse is offline   Reply With Quote
Old 09-10-2013, 08:42 AM   #14
E46@46
Re: Considering a 325xi Touring 5speed!
fuel pump
Valve cover gasket
Brakes
Cooling system refresh
Power steering pump
Disa
Clean ICV
Normal oil and filter changes
Control arms
AC compressor and dryer
Sent from my DROID RAZR using BimmerApp mobile app
Old 09-10-2013, 10:22 AM   #15
autoAER
After a certain amount of mileage,all cars need some refreshment. axels and front driveshafts are a must for most AWD cars. but in the end, we are left rolling past the RWD folks in sh#tstorm weather
Old 09-10-2013, 10:29 AM   #16
e46alfonso
My Ride: 330xi MT, mustang gt
looks like that car is lowered on HnR springs. get more info.
Old 09-10-2013, 11:22 AM   #17
SicStang03
My Ride: e46 325xiT/6 & 325ci
My H&R springs are black. Do they have black and blue springs?
SicStang03 is offline   Reply With Quote
Old 09-11-2013, 09:53 AM   #18
EDWAGON
I have 83 k miles and have replaced these items that have broke over last 5 years:
rear shocks
power steering rack ( loud clicking in rack very unsafe per INDY)
power steering pump
alternator
washer fluid pump
VCG
OFHG
Front CV Axles both
Fuel pump - left me stranded ***
front differential seal
various plastic pieces inside cabin and in engine compartment
As PM have done:
Cooling system refresh- complete see Mangos guide for this
Changed ATF fluid and filer
Changed transfer case fluid
front and rear differential fluid
belts and all pulleys
Need to fix:
Drivers window regulator
change front struts
possible oil leak from oil pan or rear main seal
Planning as future PM:
CCV
Old 09-11-2013, 10:40 AM   #19
rawbspear
My Ride: 04' E46 XIT 5 speed
i bought the 5 speed touring back in feb with 120k miles. the previous owner had not done any maintenance. she needed all new oils everywhere and the front end replaced. all the labor is pretty easy to do. I am a bicycle mechanic i have had no issues with doing all the work myself so far; cv axles, control arms, bushings, tie rods, ball joints , all the general stuff. you tube has been really helpful as well. As far as costs go, i am finding that parts are easily available on ebay, rockauto.com, amazon.com, and my local O'reilly store; got a front caliper the other day for 40$ semi loaded in less than 4 hours from time of order at o'reilly's.
if you car has spring upgrades, make sure that out check the body where the shock mounts. Everything i have read says to make sure the shock mounts get reinforced as the cars were not designed to handle the stiffer suspension and the body can crack/ break with out them..
love those rims on that one!!
rawbspear is offline   Reply With Quote
Old 09-12-2013, 12:10 PM   #20
sminnich
My Ride: 325xi,e46m,e36m,e30
I wouldn't be afraid of the maintenance. Like rawbspear just said, you can find DIY's on youtube for everything. Also, if you have a problem, it's almost guaranteed that it has been discussed on here. I'm at 180k in my XI and she has yet you let me down. The only things I've had to do are expected things: control arms, shocks, change oil, fuel pump(at 170k), and I had to replace my SEP.
I'd say go for it. you won't be disappointed.
sminnich is offline   Reply With Quote
