E46 Xi Forum
Old 10-10-2013, 11:50 AM   #1
zimzima330
My Ride: 2005 330xi
Weird vibration when cold??
When i start my car in the morning, at idle you feel small vibration. Then i drive for about five minutes and vibration goes away. Almost feels like a wheel bearing but all of that is tight, and you feel slight vibration at idle so obviously not that.. Any ideas? Sorry guys it is a 2005 330 xi 3.0, Maybe i can get a replie now lol
zimzima330 is offline   Reply With Quote
Old 10-10-2013, 03:42 PM   #2
zimzima330
My Ride: 2005 330xi
Can someone please tell me why 40+ people have veiwed but no info?? Does there need to be more info provided? If so i wouldnt know what else to say.
Old 10-10-2013, 03:59 PM   #3
Kubica
My Ride: 2003 325xi
It's the secondary air pump system. Normal vehicle operation.
Check passenger side motor mount too.
Old 10-11-2013, 01:15 PM   #4
zimzima330
My Ride: 2005 330xi
Ok thanks.. Do you think something like that would throw c.e.l? I have no codes i dont know if that changes anything?
Old 10-11-2013, 01:27 PM   #5
SamDoe1
My Ride: 4cyl of fury
If it's bad or not working, it'll throw codes. If it's fine, it won't which is where yours seems to be at.
Old 10-11-2013, 03:44 PM   #6
zimzima330
My Ride: 2005 330xi
So that narrows down that. I wouldnt think it was a motor mount either since it only does it from dead cold start and only last for about first 5 minutes, after that is smooth as butter.. So lol back to square one, any other suggestions?
Old 10-11-2013, 04:13 PM   #7
SamDoe1
^ There's probably nothing wrong with your car dude. The SAP system that Kubica described before runs for 2-5 minutes at cold start to warm up the catalyst in your exhaust system to improve emissions. If you have a vibration for 5 minutes on a cold start, this is likely the reason for it and is completely normal.
If you want to be completely anal about it, go ahead and replace the SAP, valve, and hoses but there's really no reason to do that.
Also, if you are that concerned about it, please take your car to a qualified mechanic for him/her to look it over and see what the deal is. Diagnosing a car over the internet based only on the words written by a total stranger hundreds of miles away isn't the best way to solve a problem. We can offer help and ideas but only you and your mechanic (if you have one) can truly diagnose and resolve an issue.
Lastly, the reason 40 people looked and didn't answer is because they didn't know the answer. Would you rather have 40 replies saying they have no clue?
Old 10-12-2013, 08:21 AM   #8
zimzima330
My Ride: 2005 330xi
That makes sense, now i know what the other guy meant by normal operation.. Well i just want to say thanks and i appreciate the info
Old 10-14-2013, 10:56 AM   #9
Quinn325xi
My Ride: 325xi
My car does the same thing. when its cold in the morning I can feel a slight vibration when the car is warming up. I just let it warm up for a minute and then it goes away. I also figured since it wasnt throwing any codes its probably nothing...
Quinn325xi is offline   Reply With Quote
Old 10-14-2013, 11:01 PM   #10
fafuture
My Ride: '03 e46 325xi
It is completely normal, I thought it was a problem when I first got my BMW also. You are good.
fafuture is offline   Reply With Quote
Old 10-15-2013, 11:07 PM   #11
White_Knuckles
My Ride: 2003 325xi
Open the hood and find the canister shaped pump on the front, passenger side. Notice the sound when the pump spins up on a cold start and watch the thing vibrating in it's rubber damper mounting. Allow it it run its duration and you will have a positive diagnosis of your concern. It is normal to hear some noise and vibes but best to verify as some SAP's are excessively loud or torn from their damper kicking around in there.
