Old 09-11-2013, 05:11 PM   #1
DMahoney
My Ride: 2001 325ci
Should Sparkplug Connector Brand Be Same As Coil?
I'm going to use the DIY's for changing my own spark plugs; but I was Just wondering if the news spark plug connector should be the same brand as the coils. I don't know if there's a reason for needing them or not yet since I did not take the spark plugs out yet but I want to change them anyways they are cheap And never been done.
DMahoney is offline   Reply With Quote
Old 09-11-2013, 11:44 PM   #2
DMahoney
My Ride: 2001 325ci
Any late nighters want to answer? :/
Old 09-12-2013, 12:10 PM   #3
DMahoney
My Ride: 2001 325ci
My main thing is I have oem bremi coils but before the 2002 recall; mines 01. If I was to get new ones down the line and got the new Bosch, then I would have to replace the connectors even if they're non-symptomatic ?
Old 11-27-2013, 09:09 AM   #4
MadLow
My Ride: 2004 330CI
if you buy a new bosch ignition coil, the connector and coil are both one part since they had a design change.
MadLow is offline   Reply With Quote
