Tire-Size-Calculator.info | Compare tires and wheels + graphical demonstration - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 09-13-2013, 06:25 AM   #1
badger84
My Ride: BMW 320D
Arrow Tire-Size-Calculator.info | Compare tires and wheels + graphical demonstration
Hello Forum!
I want to introduce you to my newly released tire size calculator:
www.tire-size-calculator.info
You can compare your existing and future tires and / or wheels of your vehicle. You also get a nice graphical demonstration of how the tires and / or wheels look like in comparison.
You can calculate values such as circumference, speedometer difference, changes relevant to the ride height or the effect of wheel spacers and learn which tires or wheels fit best for your car.
I hope the tire size calculator can help you with your calculations and helps you in deciding on which tires and / or wheels to choose!
Would be nice if you have any suggestions or requests how to make the tire size calculator even more better.
Greetings Mike!
PS: Admins or mods are welcome to make this thread sticky to help also new members of the forum who could need this tire size calculator._a_
badger84 is offline   Reply With Quote
Old 09-27-2013, 08:48 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Wow, very very useful man and it shows clearly what the differences would be. Stickied.
Old 04-14-2014, 04:57 PM   #3
timshady
My Ride: 2000 323i
Holy ****. Where has this been all my life. Thank you, very helpful!
timshady is offline   Reply With Quote
Old 07-29-2014, 02:59 AM   #4
andreas0622
Send a message via ICQ to andreas0622
This is great. Thank you for sharing it.
andreas0622 is offline   Reply With Quote
Old 08-24-2015, 02:50 PM   #5
Azrojan
My Ride: 04 330Ci
This is very cool. Can save $$$ by going with a slightly taller tire 205/50 vs current 225/45. hardly a difference. Thanks for the info!
Azrojan is offline   Reply With Quote
Old 12-08-2015, 09:13 PM   #6
tonysalib
My Ride: Facelift E46 Convert
Nice tool. Just a question though, why doesn't the "Outset difference per side" change when you change the new tyre width?
I.e these 265 wide tyres are showing the same "Outset difference per side" value as those 235 wide ones (with all other figures being the same).
Does it only work out the difference between the 2 "rim faces", as opposed to entire package including the tyre? If so, it would be a nice addition to have a figure that does take the tyre width into consideration, so you can see the real difference with respect to your guards
Cheers.
tonysalib is offline   Reply With Quote
Old 12-08-2015, 11:13 PM   #7
Geo31
Ironman
My Ride: 98 M-Z3, 01 325iT
Cheers.
I'd have to sit down with Excel (not happening tonight) to verify, but it appears on the surface your assumption is correct (inset/outset) is for the wheel.
The problem with getting accurate tire info is that all tires are different and any calculation would be purely theoretical. YMMV
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Brag: For the rest of your life
Geo31 is offline   Reply With Quote
Old 12-08-2015, 11:47 PM   #8
tonysalib
Have a look at this tool (http://www.rimsntires.com/specspro.jsp) it does seem to take into consideration tyre width, so may help you as a guide.
Old 02-10-2016, 02:15 PM   #9
ahmadmaaaz
1f switch cowl panel locked short circuit to ground
ahmadmaaaz is offline   Reply With Quote
Old 05-08-2016, 11:31 PM   #10
hadzray
My Ride: 2004 BMW 325i
hi guys thanks for the script.
BTW im planning to downsize my rims from 18 inch to 15 or 16 inch due to the really, really bad roads of malaysia.
is this possible? whats the minimum size of rims for 2004 e46 325i sports package?
Refer the image below
Thanks,
Loving the beemer so far. Its definitely one of the best decision i have ever made.
Hadzray from Malaysia
hadzray is offline   Reply With Quote
Old 07-22-2016, 06:45 PM   #11
ralf
My Ride: 330i
For a 325 I think you can go to 16 inch, no less.
The 320 came from factory with 16 inch wheels.
For a 330 you cannot have less than 17 because of the larger calipers and brake discs.
Thanks,
ralf is offline   Reply With Quote
Old 07-23-2016, 08:42 AM   #12
TerraPhantm
My Ride: M3 & ZHP
*Some* 16 inch wheels fit the 330i. I used to run 16 inch winter wheels on my old ZHP with ASA JH3s
Also very nice website! Can you add an option see metric units in English?
Old 07-29-2016, 12:21 PM   #13
RegularGuy
My Ride: '01 325Ci, '11 335is
Well, here goes nothing! I picked up a pristine set of 2012 335Ci (conv) ///M 18" wheels from a friend for next to nothing (Not M3 mind you, just ///M badged wheels). Let's see if they fit my 2001 325Ci (coupe). By the info gathered from numerous wheel manufactures that is also supported by your wonderful calculator, they should fit with room to spare (admittedly not much though). Special attention was given to the backspacing of individual wheel packages that were available on each year/model where I found there is overlap. If they don't, I'll have a set of pristine ///M badged wheels from a 2012 335Ci with brand new Michelin Pilot Sports for sale
Thank you for the calculator!!!
RegularGuy
RegularGuy is offline   Reply With Quote
Old 11-24-2016, 10:48 AM   #14
such00
My Ride: 2003 330i
16" wheels on 330i
TerraPhanthm, you mention some 16" will fit a 330i I have a set 16" style 282 off a 2009 328xi. Trying to determine if they will fi my 2003 330i
such00 is offline   Reply With Quote
