APEX | Wheel Spacers available for your BMW/Free shipping to the U.S. 48! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-13-2013, 04:16 PM   #1
David@ApexRaceParts
David@ApexRaceParts's Avatar
My Ride: E46 M3
APEX Wheel Spacers
APEX BMW wheel spacers for all 5 lug BMW models except for the E39. These spacers are machined from billet aluminum and made in Europe by a TUV certified ISO9001 manufacturer. Perfect for adding needed suspension clearance between your wheels/tires, or to push your wheels out for a more aggressive look. Spacers are sold in pairs of 2, and cannot be used with stock length lug bolts. Extended lugs or a stud conversion is required to use spacers.
All Wheel Spacers
  • Can be used in any discipline: Street, Auto X, Track, and Racing
  • 5x120 bolt pattern
  • 72.6mm center bore
  • Billet aluminum
  • Anodized Finish
  • Made in Europe
5mm Wheel Spacers
  • These 5mm spacers have been tested with the APEX ARC-8 wheels.
  • There is still enough material on the OEM hub to keep wheels hub-centric and vibration free.
5mm BMW Wheel Spacers - $49.99
12mm, 15mm, and 20mm Wheel Spacers
  • APEX 12, 15, and 20mm spacers are a true hub-centric design, and a must when a proper, issue-free fitment is required. The extended hub keeps your wheels centered properly which eliminates wobble and vibration inherent in traditional spacers.
  • Without a hub extender the wheel is only secured by the lugs (known as lug centric) when a spacer is used. BMW's were not designed to be lug centric, as they have a lot of slop/play around the lugs.
  • This is the same reason why some wheel manufacturers have to provide centering rings if their wheels are not 100% BMW specific. If you don't want your car to ride like a wagon, you need hub-centric spacers.
12mm BMW Wheel Spacers - $84.99
15mm BMW Wheel Spacers - $94.99
20mm BMW Wheel Spacers - $94.99
Mandatory Extended Length Mounting Hardware
BMW Stud Conversion Kits and OEM Style Extended Lugs
  • When using any of our wheel spacers, extended length mounting hardware is required. OEM lug bolts do not have enough length to go through the spacer, and thread into the hub. Either longer OEM style lug bolts, or a stud conversion is required.
  • Both options allow for proper thread engagement. Using hardware that is too short can cause failure of lug bolts.
  • On our website you can add a set of 10 extended lug bolts to your order at a discounted price by selecting your desired finish from the drop down menu. This is enough for two spacers or two wheels. These lugs bolts are either 5, 12, 15, or 20mm longer than the OEM lugs that come on BMW's from the factory and they share the same 12x1.5 threads and 60 degree taper.
  • Available in a black or silver zinc finish. Additional lugs can also be purchased individually.
RAD Extended Wheel Locks
  • Available in multiple lengths, RAD wheel locks are a must if you're using spacers. OEM length wheel locks do not have the required length to thread into the hub with a spacer installed. These can cover 3, 5, 12, 15, 18, and 20mm spacers.
  • RAD Extended Wheel Locks allow for proper thread engagement. Using hardware that is too short can cause failure of lug bolts.
  • RAD Extended Wheel Locks are all made in Germany and Dacromet coated for protection against the natural elements.
  • 100% Quality inspection before delivery.
  • Extensive selection of unique wheel keys in multiple sizes, which makes it much more difficult to defeat compared to "one-size-fits-all" solutions from other manufactures.
  • Sold in sets of 4, RAD Extended Wheel Locks can provide protection for all of the wheels on your car.
  • NOTE: These are available in M12x1.5 thread pitch only and will not fit 2012+ BMW F30 3-Series, 2011+ BMW F10 5-Series & M5, 2012+ BMW F13 6-Series & M6, or 2009+ BMW F01 7-Series as these vehicles have use M14x1.25 thread pitch.
Ordering and Contact
  • Phone: Call (888) 499-9135 EXT. #1 for phone orders.
  • Payment: Credit and Debit Cards: Visa, Mastercard, AMEX, Discover, PayPal. Bank Wire Transfers are also available. Contact us to use a wire transfer for payment on your order.
  • Tax: California customers will be charged 9% CA sales tax.
  • Shipping: Free shipping only to domestic orders within the lower 48 states. We do ship internationally!
  • APEX Hours:
    Monday thru Friday: 9AM to 5PM PST
    Saturday and Sunday: Closed
  • Warehouse and local pickup: The APEX warehouse is at 7888 Marathon Drive, Unit A, Livermore, CA, 94550 (Map It), (888) 499-9135 EXT. #2. This is where you pick up local orders.
Last edited by David@ApexRaceParts; 02-28-2014 at 06:47 PM. Reason: Auto-save 1393634854
David@ApexRaceParts is offline   Reply With Quote
Old 09-26-2013, 08:36 PM   #2
tuby
My Ride: 2000 328ci silver
You can get them cheaper then that
tuby is offline   Reply With Quote
Old 09-26-2013, 10:13 PM   #3
e46techtuner
My Ride: 2000 328i
Very nice products!
e46techtuner is offline   Reply With Quote
Old 09-27-2013, 07:02 PM   #4
APEXraceparts
My Ride: E92 M3
Originally Posted by e46techtuner View Post
Very nice products!
Thank you sir!
Product Specialist | 925.245.0773 | info@apexraceparts.com | Facebook | Blog | Instagram
APEXraceparts is offline   Reply With Quote
Old 12-20-2013, 04:43 PM   #5
jbretz
My Ride: 01 325i
just purchased a set of 12mm spacers with extended studs. need that clearance for winter wheel setup. thanks for the help guys.
jbretz is offline   Reply With Quote
Old 05-06-2014, 04:52 PM   #6
APEXraceparts
My Ride: E92 M3
Having trouble with your fitment? Give us a call so we can better help you and recommend the proper spacer for your application.
Old 06-18-2014, 06:21 PM   #7
David@ApexRaceParts
My Ride: E46 M3
Fitment issues? Wheel spacers may be just what you need to get the required clearance against a modified suspension.
Please call, email, or pm us with any questions you may have.
Old 08-12-2014, 08:22 PM   #8
David@ApexRaceParts
My Ride: E46 M3
Wheel spacers can be a great aid in providing adequate clearance against aftermarket suspension components.
Old 09-05-2014, 06:14 PM   #9
APEXraceparts
My Ride: E92 M3
Want to push the wheels out more flush to the fender? We've got the answer here, spacers in various sizes available!
20mm spacers in photo above
Old 09-15-2014, 05:08 PM   #10
APEXraceparts
My Ride: E92 M3
Wheel spacers are in stock for your E46! We have 5, 12, 15, and 20mm sizes.
Please call, pm, or email us with any questions you may have about wheel fitment or suspension clearance issues.
Old 09-22-2014, 05:12 PM   #11
APEXraceparts
My Ride: E92 M3
Make sure you purchase the correct length lug bolts for your spacers! These are available individually or at a discounted price when purchased along with a spacer kit!
Please let us know if you have any questions about our wheels or accessories and we'd be glad to help you out!
Old 10-03-2014, 05:58 PM   #12
APEXraceparts
My Ride: E92 M3
Wheel spacers are in stock for your M3 to get that perfect wheel fitment!
