E46 Convertible
Old 09-13-2013, 06:33 PM   #1
GiveMeAcookie
My Ride: my girl
Common problems with Verts?
Hey friends, what are some of the most common problems on a convertible?
and what specific year?
GiveMeAcookie is offline   Reply With Quote
Old 09-14-2013, 11:23 AM   #2
taylor192
My Ride: 2003.5 M3
Old 09-14-2013, 11:40 AM   #3
trivium630
My Ride: 2003 325i
Top is missing
trivium630 is offline   Reply With Quote
Old 09-14-2013, 12:04 PM   #4
patrickmurray2
My Ride: 2005 bmw 330i e46
I've heard from various people that the top squeaks a little when driving I myself have never ridden in a e46 vert but I'm looking at a couple m3 verts I live in Cali and it would be nice to have a vert and a hard top, but that won't be for another year or two, I've also seen a couple threads on here where the get stuck when closing, opening or vice verse, try to find some on here or on try google
patrickmurray2 is offline   Reply With Quote
Old 09-16-2013, 09:50 AM   #5
johnrando
My Ride: '06 330 CIC ZHP
E46 is a solid vert, no real "common issues" exclusive to those vs. other E46s... they are essentially the same car, with infrastructure mods to support the top. Some experience minor top up/top down issues when parts wear, but most have DIY fixes.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 09-18-2013, 10:11 PM   #6
FryGuy
My Ride: 2001 325Cic w/ B30
if you're looking at 325 drop tops make sure it has the automatic top. A manual top was standard and you had to pay money for the power one.
within one month of ownership (2001 with 112K miles), both of the hinge covers had broken themselves, which affects the top 0% but now with the top down I have 2 square holes where there should be nothing.
but other than that not bad for a 12 year old vert.
FryGuy is offline   Reply With Quote
Old 10-02-2013, 05:53 PM   #7
wildirish317
My Ride: 2004 325Ci vert
^If you don't want problems with the automatic top, get the 325 with the manual top. I bought mine with the 2 square holes open, but it's a simple fix; costs about $16 for the parts. The part number changed in 9/2003 production, but is either 51437147719/51437147720 (right and left for earlier models) or 51438163692 (tension spring) and 51437029018 (push rod) for cars built in 9/2003 or later. The push rod and spring can be installed on either side of the car.
I'd much rather know that the top operator (me) will get the top up and down when required.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 10-02-2013, 08:10 PM   #8
Max'd out
My Ride: 04 330cic
If you have chosen well and keep it clean, one common problem is being approached when getting gas or when parking in a public area with people telling you how nice the car looks and thinking it's new. Oh and another thing is, with the top down, your hair may get a little mused up and the grin on your face may be difficult to remove. But if you are strong you may survive these little problems.
Max'd out is offline   Reply With Quote
Old 10-02-2013, 08:51 PM   #9
avneet
My Ride: 2001 330ci Vert
This is quite a tough problem to over come. I still have issues with this after 7 years of owning mine
avneet is offline   Reply With Quote
Old 10-03-2013, 02:31 AM   #10
FooFighter94
I would say the most common problem I have seen is the damn batwings.
WVU Mountaineer
-2001 325Ci Convertible Slushie
-Orient Blue Metallic
-Koni Yellows, Otherwise hella stock
FooFighter94 is offline   Reply With Quote
Old 10-03-2013, 03:11 AM   #11
FryGuy
No man the batman ears are a feature, not a promlem!
Old 10-03-2013, 04:36 AM   #12
powbmps
My Ride: 2002 330CiC
This would be the only "vert specific" problem I have had. Both of them were broken when I bought it, and there are small tears in the headliner.
The passenger seat squeaks quite a bit when no one is in it (only noticeable when the top is up). Still trying to figure out if I can do anything about that.
powbmps is offline   Reply With Quote
Old 10-03-2013, 05:51 PM   #13
sakumaxp
My Ride: 02 M3 convertible
a common problem ive seen would be the little plastic covers, either the spring is missing and needs to be replaced, or the actual plastic "door/cover" is gone.
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 10-03-2013, 07:47 PM   #14
wildirish317
The glovebox is a problem, or it will be. The $135 latch mechanism will lock you out of both the glovebox and the trunk.
Old 10-03-2013, 07:56 PM   #15
morningisbad
My Ride: E46 M3 Vert
Re: Common problems with Verts?
My damn passenger seat does the same thing!
"When makin' a questionable decision, sometimes the only way to find the answer is to shut your eyes & mash the pedal to the metal, you guys."
-Karl Welzein
morningisbad is offline   Reply With Quote
Old 10-03-2013, 08:00 PM   #16
FooFighter94
Mine was broken when I inherited my car as well, I took the mechanism apart and the white little "peg" was broken off. I replaced it with a screw that fits inside the groove and that was over a year ago. The electronic feature which locks the trunk no longer works but I can at least get into my glovebox!
Mine too
So annoying!
Also my driver side sun visor rattles CONSTANTLY. It is most noticeable with the top up as with the top down, it doesn't contact the roof.
WVU Mountaineer
Old 10-09-2013, 10:35 PM   #17
330ci05
My Ride: 330ci
Put the top down. It will stop squeaking. Works everytime.
330ci05 is offline   Reply With Quote
Old 10-11-2013, 10:28 AM   #18
aarondb4
My Ride: 2002 BMW 330CI Vert
Yep, main complaint is the squeaking of the roof. My car sounds awesome and no unwanted noises with the top down, but it up and it is a symphony of squeaks and rattles. I have determined most of the noise is coming from where the windows meet the roof so I am going to work on that and see if I can't make it a bit better. It is my wife's daily driver so I am not in it enough for it to really bother me.
2002 BMW 330CI Convertible
aarondb4 is offline   Reply With Quote
Old 10-11-2013, 11:31 AM   #19
johnrando
Knock on wood, no top squeaks for me. I've heard if you lube where the top and the windows meet, the squeaks go away. There is a thread somewhere about what to use and where to use it.
Southern California
Old 10-11-2013, 11:36 AM   #20
aarondb4
Yeah I plan to go at the seam with some cleaner and then maybe wax or gummi phledge. But my window is pretty loose in the carrier as well, it rattles when you open the door or close it. I found a few threads on tightening that up so I am gonna give that a shot this weekend.
