Old 09-13-2013, 08:27 PM   #1
westsidebimmer
Past Site Sponsor
My Ride: M3
BMW brakes specialist... you can ask questions...
Hey Guys,
Just reaching out to you E46 Fanatics groups, if you have any problems or looking for brakes or suspension, PM us. We have tech that can help you answer a simple questions.
  • Squeaky Brakes?
  • Shaking steering wheels?
  • Brake light?
Thanks WSB
westsidebimmer is offline   Reply With Quote
Old 09-14-2013, 11:42 PM   #2
TnT817
My Ride: 01 330ci
My brakes pop whenever my pedal is pressed. Sounds like the pad may be popping in and out of the caliper. Everything is tight and the brakes are fairly new Bosch rotors and performance friction pads. Any ideas?
TnT817 is offline   Reply With Quote
Old 09-18-2013, 01:09 PM   #3
ibooste90
My Ride: e46 cabriolet
When backing up slowly and i press on the brakes theres a pretty loud clunk, any ideas?
ibooste90 is offline   Reply With Quote
Old 09-18-2013, 01:32 PM   #4
Sedan Hussein
My Ride: e46
Best (cost-effective) pad/rotor setup for a daily driven ZHP? I drive it pretty hard on backroads, etc.
Sedan Hussein is offline   Reply With Quote
Old 09-18-2013, 03:12 PM   #5
My Ride: Lexus
^Brembo blanks and OEM-branded (Pagid, Jurid, ATE, etc.) pads. And a fluid exchange. All you need for your use.
Old 09-18-2013, 04:27 PM   #6
Sedan Hussein
My Ride: e46
Thanks, wasn't there a thread bashing the Brembo blanks on here though? Its always stuck with me when I see them now.
Old 09-19-2013, 11:58 AM   #7
My Ride: Lexus
Who was the thread's author? Always look at that first. That thread is a joke
Old 09-20-2013, 10:50 AM   #8
hanna
My Ride: BMW 328i
I have a question for the brakes specialist. My brake pedal makes this whining/squeaking sound upon the release only. It does not do it all the time but often enough to notice. I think it depends on temperature outside and humidity. I researched it on the forums and have a few ideas what it could be, but interested in the specialist's opinion. Thanks.
hanna is offline   Reply With Quote
Old 09-20-2013, 05:26 PM   #9
hanna
My Ride: BMW 328i
Is the specialist still in town? The questions are piling up and unanswered :-) lol
Old 09-29-2013, 11:32 PM   #10
ha9981
My Ride: 320i 2002 e46
Looking for 99% OEM BMW braking but not at 100% BMW price. I don't track or anything. And I am very clear I want OEM feel, that strong initial bite from OEM pads.
I am willing to buy 100% OEM BMW logo pads, from ECS for $136 (good deal?)
What rotors should I buy, it is hard to justify BMW rotors from ECS when my car is only a 320i. Should I bite the bullet and go 100% BMW logo OEM?
Or should I buy ATE rotors, or maybe Brembo (on RockAuto $23ea. front and $26ea. rear, says High Carbon, scared if I am cheaping out), or Balos?
So confused on Rotors!
Also heard PBC Metal Master are like OEM, worth the savings for taking a risk?
If someone here was really looking for 99% OEM feel and got it with a particular setup please point me to exactly where you got them, atleast the rotors. Want to make sure exact same model of rotors.
ha9981 is offline   Reply With Quote
Old 10-02-2013, 12:50 AM   #11
westsidebimmer
Past Site Sponsor
My Ride: M3
Re: BMW brakes specialist... you can ask questions...
We have get package deal will almost guaranteed your problems will be resolved. ..this is the package simply for daily driven good rotors, pads, sensors direct replacement
Centric rotors . Ceramic pads super low dust..2 sensors
Pm or txt me for pricing. 714-616-7637
Westside Bimmer
Old 10-02-2013, 12:53 AM   #12
westsidebimmer
Past Site Sponsor
My Ride: M3
Check what pads you have in placed? If its a street performance its will squeak when it's cold or semi metallic pads runs the same..
Suggestion.replace with ceramic set pads or oem pads will cure your problem.
Westside Bimmer
Old 10-02-2013, 02:01 AM   #13
Mflara20
My Ride: 04 330i
I get a very spongy pedal after I replace the rotors with slotted/drilled rotors and pads which I son know the bran. I already bleed the brakes and replace it with racing blue brake oil. If it helps it's a 02 330xi
And I know this brake pads are cheap but I want to see what you think about them. Thanks.
http://amzn.com/B00FBVTNWE
Mflara20 is offline   Reply With Quote
Old 10-02-2013, 08:49 AM   #14
westsidebimmer
Past Site Sponsor
My Ride: M3
Hey guy
I am unsure of the brand ss line was used. Making sure you bleed all 4 calipers with a dot 4 racing fluid you should be fine.
Or perhaps check the rotors if it's zinc coat finished and you only had them for couple weeks..the zinc needs to peel of the first layer and you should be ok.
Sometimes it just the braking in period.
Also check the sensor light to see what's up
Westside Bimmer
Old 10-02-2013, 04:45 PM   #15
Mflara20
My Ride: 04 330i
I haven't installed high performance brakes lines but I want to to that and see if that helps the spongy pedal.
Old 10-03-2013, 11:01 AM   #16
westsidebimmer
Past Site Sponsor
My Ride: M3
We stock oem and brembo brakes w/o the dealer price tag...
Send us your car specs will do everything to earn your business
Westside Bimmer
Old 10-03-2013, 11:41 PM   #17
westsidebimmer
Past Site Sponsor
My Ride: M3
Thursday bump
Westside Bimmer
Old 10-20-2013, 11:16 PM   #18
westsidebimmer
Past Site Sponsor
My Ride: M3
Old 10-21-2013, 11:30 AM   #19
masruque
My Ride: 325ci
hey,
my steering is shaking on braking with a loud hum. guessing it is warped rotors. I have the stock m-package drilled rotors. what new rotors do you suggest? and what kind of pads? she is my daily driver
masruque is offline   Reply With Quote
