Old 04-23-2014, 02:17 AM   #41
zaharias
My Ride: M3 E46 6MT 3/2005
Anyone know if these software issues also exist @ MS43 M54B30 VF SC cars..??
zaharias is offline   Reply With Quote
Old 04-23-2014, 08:58 PM   #42
pokeybritches
My Ride: G-Power Z4M, VF Z4
Originally Posted by mike@maximumpsi View Post
Does the car currently have any fuel trim or MAF codes? Does the afr still look like the dyno graph in the pic you posted above? We just finished an install on a customer's Z4 with a MS45 ecu and the afr plot is off the chart rich in the midrange just like your graph. Also, what year is your car? MS45 ecu?
-Mike
Pulled the codes tonight as promised. I still have a P0172 and P0175. Will update when the flash tuner arrives.
G Power Z4M and VF Engineering Z4 3.0i
pokeybritches is offline   Reply With Quote
Old 04-29-2014, 05:14 PM   #43
pokeybritches
Originally Posted by Rob43 View Post
What's your Build date (month & year) on your door jam, this will indicate whether you have a MS43 or MS45.1.
For instance my 330Ci is a 2003 also, so most would think it's a MS45.1 . But its build date is 8 or 9 of 2002, this makes it a MS43 .
Build date is September 2003.
Old 05-01-2014, 05:01 PM   #44
zaharias
Question
Ive done around 4-5.000 kms since doing headers+200 cell Magnaflow cats and i got today for the second time in a month, a CEL for "catalyst eficience bank 1 & 2".. All 4 02 sensors are BOSCH new, i have them nearly 20.000 kms..
Do you have similar faults with your cats?
Old 05-01-2014, 10:24 PM   #45
pokeybritches
Yes. Your cats aren't big enough.
Old 05-02-2014, 04:47 AM   #46
zaharias
Thanks for the reply mate!
What cats do you have?
My cats are 200 cell metal cats Magnaflow (i think 55mm OD, the rest of the exhaust is stock diameter) and it just doesn't make sense cause ive done around 5K kms with no CEL at all and it showed up 2 times in a month now.. after 5K kms..?? I will check the 02 readings..
Old 05-02-2014, 10:33 AM   #47
pokeybritches
It's the cats. And "big enough" isn't technically the correct term. The computer compares the AFR of the second set of sensors to the AFR in the first. If the difference isn't within certain parameters, it throws a code.
Check out HJS cats.
Old 05-02-2014, 12:15 PM   #48
zaharias
Check out HJS cats.
If i delete the rear 02 sensors with software when i fit the VF kit?
Sorry for messing up your thread!
Old 05-02-2014, 12:25 PM   #49
jdjg
My Ride: e39, m52tub30
do it
jdjg is offline   Reply With Quote
Old 06-03-2014, 12:13 PM   #50
pokeybritches
Update - received my ECU back from VF with the new tune. They followed up with an email and phone call to see how I liked it and mentioned they spent a bit of time tweaking it based on the dyno.
I'll reinstall the ECU once I get my headlight back from Tekarbon, and the car is again road legal. I'm expecting to have it back June 10.
Old 06-03-2014, 01:15 PM   #51
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
In for (good) results.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 06-20-2014, 05:47 PM   #52
s14realm3
My Ride: 03 ZHP, 95 M3, 91 M3
I also have a vf v2 kit in my zhp. I did the install myself. I got the kit used from a local memeber and watched his mechanic remove the kit from his car. Except I wasnt so sure about the hoses coming off the big VF plastic snokle. Its running ok and no CEL so I think I got the routing connection right. I am looking to install an oil catch can and delete the ccv. I am buring too much oil now. Have you looked at a can?
s14realm3 is offline   Reply With Quote
Old 09-18-2014, 12:29 PM   #53
zaharias
Hi mate..
Any updates?
What issues did you have when you were installing the kit (cause it originally was for E46, not Z4)? I wanna see the differences.. ive got someone who wants to buy my kit..
Old 09-19-2014, 12:00 AM   #54
s14realm3
Other than a loose blow off valve hose, in have had no issue. I am about to install a boost gauge to see how much boost I am running. I did remove 80% of the kit last month to find that loose hose and its not that hard to do now. Experinece gets better and faster.
Old 09-19-2014, 07:35 PM   #55
pokeybritches
The car runs perfectly. Here's a quick video:
Old 09-19-2014, 07:50 PM   #56
pokeybritches
One thing I didn't mention - I put on 265/35/18 rear tires (stock are 255/35/18, so the new tires slow acceleration a bit).
Old 10-12-2014, 05:23 PM   #57
pokeybritches
I had some time today to compile some of my Z4's videos on my iPhone.
Hopefully it will help anyone on the fence answer:
What will the car sound like?
How much power will it make?
How fast will it be?
What's the AFR like?
Old 10-12-2014, 07:01 PM   #58
zaharias
Thumbs Up
Thank you for the video man!!
Nice video!!!
Old 03-21-2015, 04:12 PM   #59
Rob43
Rob43's Avatar
Pokey, I sent you a PM.
Rob43
