Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Great Lakes
Great Lakes
IL IN MI MN OH WI
Old 09-16-2013, 07:40 AM   #1
Rocket22
My Ride: 2003 325Ci
anyone able to lend a 48mm socket and breaker? Chicagoland
I thought I had a well stocked garage, air tools, 1/2 dirves up to 36 MM, and then I get to replacing the Hub after breaking off two frozen lug bolts (Tire was not removed for 4 years...(I am guilty of not bleeding brakes every two years, last done in 2009 ish)
So I have another post for Hub questions, but what I am looking for is the BMW 48MM Hub tool and 3/4 breaker. I will source these if needed, but would think this forum normally resourceful so I am asking. I will pay for the stuff and then ship back, or if local, will pick up and leave deposit. I just need the socket, I can get the 3/4 breaker bar.
I have checked most the local auto parts stores and 48 MM sockets are not in the loner programs. I have also heard some of the impact sockets will not work due to size.
Any suggestions?
Rocket22 is offline   Reply With Quote
Old 10-19-2013, 09:42 PM   #2
Cayne23
My Ride: 2002 m3 convertible
Re: anyone able to lend a 48mm socket and breaker? Chicagoland
Um. If you're talking about the axle nut under the dust cap, its actually a 46mm socket needed. Check sears or a harbor freight store if u have them around there. A 1-13/16 inch socket is the same size. Thats what I had to use. Rears are 36mm
Cayne23 is offline   Reply With Quote
