Did my valve cover gasket and wow was it shot - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 09-16-2013, 10:48 AM   #1
Arnezie
My Ride: 04 325XI
So decided after several months of small leaks around spark plugs and areas around the VCG I decided to change it. Such a simple job can't believe I was slightly intimidated to attempt this. 90 min later I was done. So if your thinking about it here is my tip be careful if yours is old like mine (164000 and it was the original )it will break apart and small pieces may fall into the engine. Forceps and a bright flask light help here I spent 10 min playing operation picking all of the pieces out. Click image for larger version
Arnezie is offline   Reply With Quote
Old 09-16-2013, 11:48 AM   #2
bikesandcars
My Ride: 2002 325xi-sport pkg
Originally Posted by Arnezie View Post
So decided after several months of small leaks around spark plugs and areas around the VCG I decided to change it. Such a simple job can't believe I was slightly intimidated to attempt this. 90 min later I was done. So if your thinking about it here is my tip be careful if yours is old like mine (164000 and it was the original )it will break apart and small pieces may fall into the engine. Forceps and a bright flask light help here I spent 10 min playing operation picking all of the pieces out. Attachment 526813
Good work. I discovered the same brittle components on my 120K engine. I got out any large pieces I could see. If I missed a smaller one or two I assume it will be drained in the oil or caught in the oil pump screen.
I've never seen a rubber gasket that brittle. Do you folks think it's the environment (high temp?) or the rubber that BMW is using?
bikesandcars is offline   Reply With Quote
Old 09-16-2013, 12:46 PM   #3
Arnezie
My Ride: 04 325XI
Well my car has lived it's entire life in Michigan so no extreme temps here. Got to be the rubber they use.
Old 09-16-2013, 04:17 PM   #4
SamDoe1
My Ride: 4cyl of fury
I put shop rags in the bottom of the valve housing when taking the gasket out. That way I could trap most of the stuff and lift it all out at once. Make sure you pour some new oil on the stuff in there to re-lube it before you put back together.
