Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 26 votes, 4.08 average. Display Modes
Old 09-19-2013, 09:45 AM   #21
zander271
My Ride: 6spd ZHP/5sp XI
So, you wanna service the rear trailing arm? Definitive Trailing Arm Guide
Mango loving the thread!
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 09-19-2013, 09:47 AM   #22
My Ride: Lexus
THANKS BOSS!!
Old 09-19-2013, 09:48 AM   #23
Zell
Zell's Avatar
My Ride: so turbo wow
Originally Posted by sunsetcoast View Post
+1. For example, what is the reason to choose the balljoint type bushing from the M3 vs the standard one?
M3 one is going to be beefier and more performance-oriented. To me, that translates into a harder ride, but better performance in turns.
It all depends what you're looking for. If you like the stock E46 ride quality, you'll wanna stay with Lemforder.
How much of a ride difference you'll actually notice is entirely subjective to how picky you are about stuff.
Old 09-19-2013, 09:51 AM   #24
My Ride: Lexus
yup I thought that was pretty obvious given all the discussions we have here.
non-M.....M3....non-M.... M3... rubber.....metal.....rubber....metal.
Old 09-19-2013, 10:36 AM   #25
RudyT
My Ride: 2001 330i
Originally Posted by Brad W View Post
I've seen a variety of options for the RTAB tool, but even to buy it isn't too big a hit on the wallet. That other bushing set is a bit steep.
What other fancy tools are needed just to get to the point of using that bushing tool set?
For removal, you can rent these two tools from autozone:
OEM/Ball joint/U-Joint press set with 4WD service set
http://www.autozone.com/autozone/acc...questid=119534
OEM/Ball joint adapter set
http://www.autozone.com/autozone/acc...questid=119830
Use the C Clamp and end cap, find the correct sized end, and then use a breaker bar to start pushing the bushing out. Keep going until everything falls out.
Hope that helps!
EDIT: Resized and updated links.
RudyT is offline   Reply With Quote
Old 09-19-2013, 10:38 AM   #26
jfoj
My Ride: 330CiC, M5, X5, E93
RudyT - RESIZE PLZ!
I see you are in process. Thanks
Old 09-19-2013, 10:45 AM   #27
My Ride: Lexus
I hope that Autozone tool setup takes into account the "ears" on the new RTABs. otherwise you'll destroy the bushing if you used a half-assed tool. It also appears that the plate used in the above photos is cocked in the photos. This means its going into the trailing arm crooked which increases the likelihood of pressing the bushing in crooked. that will destroy it. be careful with such tools. personally i'd just use the MIS tool. lots of people may rent it to you
Old 09-19-2013, 10:47 AM   #28
RudyT
My Ride: 2001 330i
Should have mentioned that this was used for removal only. I used Powerflex bushings, so those were hand-pushed in
Old 09-19-2013, 10:49 AM   #29
My Ride: Lexus
Yeah that's the thing. Also not sure I'd trust something pressed in with hand pressure that's supposed to be pressed.
Old 09-19-2013, 10:51 AM   #30
RudyT
My Ride: 2001 330i
The Poly's come as a two piece, just coat with the provided copper-based lube, and snap in both sides. Then off for an alignment
http://www.bimmerzone.com/BMW_Perfor...-3608-E46.html
Old 09-19-2013, 10:58 AM   #31
My Ride: Lexus
I'm well aware of what they "come with" and how they look.
Old 09-19-2013, 12:52 PM   #32
Kubica
My Ride: 2003 325xi
If your trailing arm bushing (lower) is in good condition, you can get by with the M3 balljoint upgrade without an alignment.
No that's incorrect.
Camber will be off if you replace the lower bushing with a ball joint.
Old 09-19-2013, 12:53 PM   #33
Zell
Zell's Avatar
Originally Posted by Kubica View Post
I disagree.
I don't know how you can disagree with that, it saves a lot of time looking this stuff up on your own. Just bookmark a thread with all the info and you're done, no more googling. Glad someone did it for me.
Old 09-19-2013, 12:59 PM   #34
cposk
My Ride: 08' E90 M3
Shouldn't be, there are clear markings on the eccentric bolt/washer. Like Mango said, the bushing needs to be in good condition though. If its shot, then your camber was probably off (and variable) anyway.
ON A SIDE NOTE - I just hit an E46F milestone, being mentioned in a MANGO informative post.
cposk is offline   Reply With Quote
Old 09-19-2013, 01:03 PM   #35
My Ride: Lexus
Absolutely correct. If the center-line of the bushing/balljoint is good (good condition) then there will be little to no meaningful difference in bolt location and thus alignment won't be off.
If you're really savvy and knowledgeable, you actually rarely need to align the rear. I've verified time after time again that my alignment is spot on even after replacing stuff. But for all intents and purpose, an alignment is always recommended.
Note I say recommended and not necessary.
Edit:
And yes credit is given where its due. The idea to replace the bushing with balljoint was all you, my friend. Without you, I would not have known. I just couldn't use your home made tool idea.
Old 09-19-2013, 01:19 PM   #36
sunsetcoast
My Ride: '99 323i & '00 323iT
Thx, Zell.
I obviously have a lot to lean about rear suspension, but...
How do you define "better performance in turns"?
sunsetcoast is offline   Reply With Quote
Old 09-19-2013, 01:21 PM   #37
My Ride: Lexus
Thx, Zell.
More control and feedback at the expense of increased noise and vibration. It also is more expensive. Lots of reasons the non-M did not come that way from the factory. Simply doesn't fit the model.
Old 09-19-2013, 01:24 PM   #38
Zell
Zell's Avatar
Thx, Zell.
Generally "better performance" will equate to grippier in turns and more direct feedback from the road (e.g. you can feel exactly what the car is doing better and it isn't damped out as much), but there are also other factors depending upon the part you replace. In this case, there are a few different ways it contributes to better performance.
Here's a good read on what the RTABs do.
http://www.rogueengineering.com/bmw/RTAB.html
Old 09-19-2013, 02:49 PM   #39
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I should probably do mine, huh?
Nice thread, Mang!
See me in June!
dmax on Facebook
Mangofy your E46!
Old 09-19-2013, 02:56 PM   #40
cposk
My Ride: 08' E90 M3
You will not notice any NVH with the balljoints unless you are a hypersensitive person. These points are not directly connected to the chassis (the vibration has to go through a second bushing to get to the car, either the TA Bushing, Shock/Spring, Subframe bushing). This mod just helps to tighten things up/reduce variation when under load, which will translate to better handling characteristics.
