Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 26 votes, 4.08 average. Display Modes
Old 10-12-2013, 09:11 AM   #101
ti317
My Ride: 02 330ci coupe 5 spd
Mango, help!
The new bushings went in easily but they are off center in the arms. That is more of the metal covering shows on one side of the arm than the other. The arms do fit easily into the carriers, even with limiters in place.
Should I worry about it, or could is be just a design difference? I am using Bilstein/Febi bushings.
I have everything assembled but not torqued yet.
The only difference between death and taxes is that death doesn't get any worse every time Congress meets. - Will Rogers
ti317 is offline   Reply With Quote
Old 10-15-2013, 03:00 PM   #102
001
My Ride: 01 330ci
This is why everyone should tackle this. Mine were completely SHOT. And there is a significant difference in how the car handles. On the one side, the metal outer casing is completely gone.
ID:	530943   Click image for larger version
001 is offline   Reply With Quote
Old 10-15-2013, 03:24 PM   #103
My Ride: 2016 Lexus
Originally Posted by ti317 View Post
Yeah but if we don't try new things, we never progress. The trick is to identify quickly when it's time to get back in line before you do any damage.
there's no point in wasting your time in what you described. if there was a more efficient way of doing it, i would let you know.
Mango, help!
i don't know. i can't vouch for febi bilstein.
Old 10-15-2013, 10:13 PM   #104
ti317
Yikes! Mine looked like new but I am in Florida. Great roads, sweeping curves and no hills.
Old 10-15-2013, 10:18 PM   #105
ti317
Your modesty knows no bounds. That's why so many flock to you.
I'll just torque it all up and get it aligned and see what readings they can get.
Old 10-16-2013, 03:22 PM   #106
latitude39
My Ride: 2002 325xi (163k)
Definitive Trailing Arm Guide
Rubber mount part number (2 per car on non-M models): 33326771828
M3 balljoint part number (2 per car on non-M models and 4 per car on M3 models): 33326775551
These are torqued to around 78 ft-lbs (99% sure) if someone can find the official spec, I'd appreciate it.
E46 Bentley p. 330-6 states 81 ft-lbs for all 3 RTABs.
latitude39 is offline   Reply With Quote
Old 10-17-2013, 03:03 AM   #107
YOnpds
My Ride: E46
How many miles were on those? Yikes!
YOnpds is offline   Reply With Quote
Old 10-17-2013, 10:51 AM   #108
My Ride: 2016 Lexus
it helps but i don't like bentley nor do i use it. they make ford bronco and toyota tercel books. they're the walmart of car manuals. they've been off on many other things in the past.
Old 10-18-2013, 06:50 AM   #109
ti317
What do you use? I have a Bentley for my S4 not crazy about it, that's why I didn't buy one for the e46. I have a Chiltons for the E46 but I research everything as the Chiltons is kind of like a comic book. I use it for a quick reference but rely heavily on some guy on the boards called Mango. Do you know him?
By the way, Chiltons has the same torque numbers.
Old 10-18-2013, 11:08 AM   #110
My Ride: 2016 Lexus
That's fine. I'm not saying Bentley is wrong on everything, but in general, I don't give them any thought. They should be generally right on torque specs and people will often repeat those on the internet. But in terms of practices, etc., I don't trust them. I believe they say to lubricate the caliper guide pins. One example. Anyway, I don't use any manuals. Just learn as I go along and call up memories of TIS when it was online.
Old 10-18-2013, 12:03 PM   #111
latitude39
BMW TIS (12/2007 version) says:
11AZ Upper/lower control arms to trailing arm: 110 Nm (81 ft-lbs)
12AZ Trailing arm to console: 110 Nm (81 ft-lbs)
"console" can only mean the bracket that connects the trailing arm to the body.
Conversion to ft-lbs: Nm * .738
Old 10-18-2013, 01:26 PM   #112
My Ride: 2016 Lexus
yeah the single 18mm bolt that goes through the trailing arm bracket is 81 ft lbs or so. the three 18mm bolts to the body are around 57 ft lbs iirc
Old 10-19-2013, 09:59 PM   #113
ti317
Finished the RTABs. I had to press the Febi bushings further into the arms as the way they were, made it next to impossible to catch the 3 bolts on the carriers.
I installed limiters, I think they were Delrin and it seemed they made it very easy to achieve zero preload. Taking it Monday for a set of Pilot Sports A/S3 s or Super Sports.
Haven't decided yet.
Even though my RTABs were not that bad, pulling the tires off revealed hidden tire damage on the inside of one tire.
Old 10-20-2013, 07:02 PM   #114
smolck
My Ride: 2004 ZHP Sedan
Replaced all mine this weekend. Was able to remove and install bushings using my homemade press. Install is simple reverse of what you see. I just haven't uploaded the video of that yet. It may not work if you live in a snow prone area as you will have more corrosion than my car. But it worked quite easily. I use an air chisel to muscle the front bushing out, I installed powerflex. After alignment the car feels a lot more stable. Very worthwhile indeed.
Check out my BMW Blog
http://smolckbmw.blogspot.com/
Check my Youtube channel for DIY's and fun stuff
http://www.youtube.com/user/flipfinish?feature=mhee
smolck is offline   Reply With Quote
Old 10-21-2013, 07:49 PM   #115
ti317
Update. Did not do the FCABs as I am waiting for delivery of a bunch of bolts from a dealer in ME( 32 @ $2.02 compared to $5.85 that the dealers here want).
Decided to go with the Pilot A/S3. Love he ride comfort but I need to not drive the car for a while till I can change the FCABs. The alignment tech checked them for me and agreed I should wait until they are changed.
The RTABs with limiters the rear end really feels tight and is quiet so far. The front is now a littler looser feeling but that will be solved soon. Can't really say how the handling is as I cannot drive it hard or long right now.
Old 11-06-2013, 06:53 AM   #116
ti317
Final report.
Got FCABs done (I was away on a cruise, so it took a while) got a good alignment done. So far, the car feels fantastic! I am breaking in the new tires so I have not driven it hard yet. It feels like new!
It's amazing how looseness creeps up on you in a DD so you don't notice it unless something is actually wrong.
Refresh list to date:
FCABs, TABs, checked stabilizer bar links and bushings. Koni FSDs <15k miles ago.
Active Autowerke front strut brace (At about same time as FCABs)
18" Michelin Pilot A/S 3
Love the result!
PS. Big thanks to Mango for his many informative posts on suspension refresh.
Old 11-06-2013, 11:09 AM   #117
My Ride: 2016 Lexus
Final report.
Love the result!
nice. post pics of your car! and the suspension/wheels/tires.
what wheels?
Old 11-06-2013, 02:25 PM   #118
ti317
So, you wanna service the rear trailing arm? Definitive Trailing Arm Guide
what wheels?
Car is not much to look at but drives awesome.
18" Type 162 staggered wheels.
It's filthy right now due to construction next door. I'll wash it if it doesn't rain and post a pic in a bit.
Old 11-06-2013, 03:07 PM   #119
ti317
what wheels?
Quick wash still needs some cleaning.Click image for larger version
Old 11-14-2013, 04:25 PM   #120
BigDRick323
My Ride: 2000 323i
GOT almost all my suspension parts together, quoted $1000 for front and rear minus the shocks. Worth doing myself or just have the shop do it?
