Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 26 votes, 4.08 average. Display Modes
Old 01-28-2014, 11:45 PM   #141
ti317
My Ride: 02 330ci coupe 5 spd
Originally Posted by Mango View Post
what are lemforder limiters? can you link these to me?
ECS carries them. They are plastic limiters made by Lemforder IIRC. I will have to check the invoice.
The only difference between death and taxes is that death doesn't get any worse every time Congress meets. - Will Rogers
ti317 is offline   Reply With Quote
Old 01-30-2014, 04:39 PM   #142
Phoenix330ci
My Ride: 04 330Ci Convertible
Mango,
http://www.oembimmerparts.com/BMW_M3...7kiteoemm3.htm
These here at OEMBIMMER.
Phoenix330ci is offline   Reply With Quote
Old 01-30-2014, 06:19 PM   #143
My Ride: Lexus
Originally Posted by Phoenix330ci View Post
Nope. Just as I thought, the RTABs are Lemforder. The limiters are aftermarket and tossed in as a kit. That's why it's called a kit. Lemforder would have no bushing making limiters as they don't come as factory equipment. Nothing wrong with them, just know they aren't Lemforder.
Old 01-30-2014, 06:20 PM   #144
My Ride: Lexus
^*meant business, not bushing.
Old 02-02-2014, 01:47 PM   #145
Dazza335iC
My Ride: '02 330Ci, '92 345iC
On the split bushings, does the orientation of the split matter? Should they be vertical, horizontal, etc?
Dazza335iC is offline   Reply With Quote
Old 02-03-2014, 11:24 AM   #146
My Ride: Lexus
It's been a while since I've done it but I think it goes down/up. search around
Old 02-03-2014, 12:05 PM   #147
Gus330vrum
My Ride: 330ci
Anyone wants to rent me one?
Sent from my using BimmerApp mobile app
Gus330vrum is offline   Reply With Quote
Old 02-03-2014, 12:39 PM   #148
Phoenix330ci
The way I have seen it done.....(l).......so split vertical. Don't know if it really matters though. I have one more source to check but it is at home.
Old 02-03-2014, 01:16 PM   #149
Dazza335iC
I couldn't find any info while searching, but the old ones were vertical so I put the new ones in vertical as well. I followed Mango's advice on how to set pre-load on the RTABs, and set preload on the inner LCA bushings by jacking up the hub to roughly static height and then tightening the bolt going through the bushing fully. Hopefully that's an OK method??
Old 02-10-2014, 11:17 AM   #150
BigDRick323
My Ride: 2000 323i
Best tool set best price to do all the rear bushings.
Old 05-10-2014, 05:50 PM   #151
rkneeshaw
My Ride: 330i ZHP
Just did this today.
Nobody should try to do this without the proper tool, I can't imagine trying it. I used the KTC rear axle service kit and it worked GREAT. Bushings all came out and went in like butter.
I went with powerflex RTABs and upgraded the lower outer control arm bushings to the M3 style
Room for limiters in there, I noticed... not sure if that would be a good idea or not (to pair limiters with poly RTABs), so I emailed powerflex.
I didn't have to remove the rotor, but I did remove the caliper to take pressure off the brake line (was getting pulled on with the suspension fully drooped)
The upper outer rear control arm bushings (the ball joint style) seemed perfectly fine. I probably didn't need to replace them, but had the parts so went ahead and replaced them anyway. I have 94k miles on my car. I suspect those ball joint style bushings will probably last a lifetime.
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 05-27-2014, 08:17 AM   #152
typeflex
My Ride: e46
Ohhh man, this is the abundance of information on rtab's I was looking for. Thank you a million times over Mango.
typeflex is offline   Reply With Quote
Old 05-27-2014, 06:01 PM   #153
rkneeshaw
My Ride: 330i ZHP
Update: powerflex says not to use limiters with their RTABs. They say the poly restricts the movement the same as the limiters do, so no need for them.
2003 BMW 330i ZHP
Old 06-23-2015, 04:04 PM   #154
clabcon
My Ride: e46 330 Ci
When upgrading the lower rubber mounting on a 330 for a ball joint from an M3, do you also need to change the eccentric camber bolt and washer? The M3 bolt is 98 mm long vs 82 mm for the 330.
clabcon is offline   Reply With Quote
Old 06-24-2015, 12:57 PM   #155
Brad W
My Ride: 2003 330ci
I didn't need to change that. Didn't even have to remove it.
ZPP, ZSP, ZCW
Brad W is offline   Reply With Quote
Old 08-25-2015, 02:27 PM   #156
CharlieFoxtrot
My Ride: 02 330Ci
Thanks Mango (and other commenters)! I just ordered the RTABs, limiters and M3 joints (all Lemforder except the limiters), plus sway bar bushings & links f&r from FCP, and the MIS tool from MIS. Hoping I don't find bad diff or subframe bushings, as I'm really not in the mood to do those in the driveway...
I did the FCAs, bushings, etc, a few months ago, along with springs, shocks, struts, mounts, etc. And I have an AC evap waiting for the last recharge to leak out again...
CharlieFoxtrot is offline   Reply With Quote
Old 09-14-2015, 12:46 AM   #157
Archbid
My Ride: 2003 330cic
Just did the ball joints and RTABs this past week. RTABs were a breeze with the MIS tool (rented). upper and lower ball joints were harder, and I made a tool. I was not going to buy a ball joint set for $400 for this job. The core of the tool was a 7/16" threaded rod and couplers from HD, Simpson square washers, and hardened round washers. I used three different electrical conduit couplers for the press and receivers, and the whole thing worked great. Only issue - I stripped my first rod by using standard nuts instead of couplers.
Put four ball joints in, and the old ball joints were definitely worn. Rubber was in great shape, but the actual ball joint was floppy like a sleeping cat.
Not an "easy" job - it takes strength with the tools I was using. But not a difficult one to figure out.
Archbid is offline   Reply With Quote
Old 12-16-2015, 10:50 AM   #158
My Ride: Lexus
Sure no problem!
Nice work on the tool. All the times I tried making special tools for the BMW rear end, they failed. Snapped crackled or popped. The rod seems to be the weak point. Hard to find a good rod.
I did not need to touch it. Perhaps the control arm is a different thickness/width? There was plenty (same amount) of rod sticking out from what I remember. But if you have the parts, why not.
Agreed here
Any time
Old 12-16-2015, 11:15 AM   #159
CharlieFoxtrot
My Ride: 02 330Ci
Agreed here
The Q&A above seems quite straightforward, so I don't know how I could be missing something, yet... The eccentric bolt is what holds the camber rod to the lower bushing. How could you change the bushing/balljoint yet not have to remove the bolt?
I didn't know there was a difference in the M3 bolt length, but since the bushings/balljoints are interchangable, and since the non-M camber rod still fits the upgraded joint, I have to believe the longer M3 bolt is not required. I don't even see a reason for the M3 to have a longer bolt, especially since RealOEM says the control arm is the same for both models, 33326770813.
Old 04-08-2016, 05:16 PM   #160
Huajiachicat
My Ride: 2006 BMW 325Ci
Nice write up. Thanks Mango! I am ordering the bushings/ball joints now and plan to start this project soon.
I found some complex tool sets online, most of them are made in Taiwan. It seems those set have a different design from MIS tool. The tool manufacturers claim for multiple bushings/balljoints in rear trailing arm. I am wondering anyone have experience on that. Plus, they are more expensive than MIS, usually 2-3 times. Are they worth to buy?
Huajiachicat is offline   Reply With Quote
