Old 09-18-2013, 04:05 AM   #1
The BeastM3
My Ride: E92 M3
BMW 330I Turbo
Hi, I'm relatively new to this forum. I've been browsing and found some interesting threads. I was wondering if you guys could assist me.
I would like to Turbo charge a 330i however some people says that the compression would be too high with the 3.0 crank. I will be running Arias 84.5mm pistons and 135mm eagle rods. Would this application work?
Regards
The BeastM3 is offline   Reply With Quote
Old 09-18-2013, 05:15 AM   #2
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Regards
It depends on the fuel you run, and how much power you want to make.
The Technique Tuning turbo kit makes over 300rwhp on stock compression with pump (91 octane) fuel. Jimmy in Sweden made 500rwhp with a stock engine using E85 fuel.
In the RSA you don't normally have the best fuel, so dropping the compression to 8.5:1 with pistons, or a 0.140" thick head gasket, would be a wise decision to make between 300-400rwhp.
Old 09-18-2013, 06:18 AM   #3
The BeastM3
My Ride: E92 M3
Thanks for the response. My goal is 540hp as the car will be used for track purpose.
This is what i have heard from tests.
- a 3.0 crank gives you a comp ratio of 9.5
-a 2.8 crank gives you a comp rstio of 8.56
We've got AVGAS in RSA which is 100 octane however the E85 would be best
Old 09-18-2013, 03:58 PM   #4
zander271
My Ride: 6spd ZHP/5sp XI
BMW 330I Turbo
Didn't Jimmy find out that e85 also better because its runs a bit cooler IE slightly lower engine temps? I know trying to hit 500 he was having some temp issues if I remember. Ill try to find the post but I'm on the pot taking a dump lol!!!
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 09-19-2013, 01:50 AM   #5
The BeastM3
My Ride: E92 M3
Lol.. Thanks man. Would appreciate that. I'm curious to know what comp ratio does the 3.0 crank give seeing that the stroke is 89.5 in comparison to the 2.8 crank which stroke is 84
