Old 09-18-2013, 11:43 AM   #1
Antti
My Ride: German car
fault code: "12 Powerwindow: open circuit motor or relay passenger side behind"
Hi to all!
Car: E46 330CIA Convertible 2004 with 138.000kilometres.
Problem with passenger side rear window:
Sometimes when i open electric roof, right rear window would not return normally up after roof cycle has finished.
If i try manually lift window up from that window individual switch, it would not go up. Only down direction works.
Then i have to move electric roof in some direction, and after that test that switch for up then window will raise normally. Sometimes if i turn car ignition power off and on back then i am able to lift window up.
Problem is only that one rear window, all 3 other windows work perfectly.
I took INPA and look for fault codes. There was no codes in the roof control module, but in the Central body electronics module there was this code:
12 power window: Open circuit motor or relay passenger side behind.
Error frequency 9 Sporadic error
Errorcode 0C 09
Do you have any ideas what should i replace first?
Antti is offline   Reply With Quote
Old 09-18-2013, 11:57 PM   #2
Antti
My Ride: German car
I will change that GM5 module rear window relays first.
Old 09-26-2013, 12:05 AM   #3
Antti
My Ride: German car
Now the rear windows relays has been replaced, i will test periodically rear windows. It is way too cold for opening roof in this time of year.
Module fixed:
Old 10-07-2013, 11:35 PM   #4
Antti
My Ride: German car
There has not been any more rear window faults, so i suppose problem is now fixed. Car is now in the winter storage.
