///M3 Forum
Old 09-18-2013, 12:43 PM   #1
PiL
My Ride: 2006 | M3 | CBM
Correct placement of anti-seize on spacer?
Received my spacers and plan to install later today. Where is it appropriate to apply the anti-seize? I have read only the center of the hub (inside lip) area and not on the backside of the spacer that lies against the hub (b/c could cause vibration)?
Thanks!
2006 | M3 | CBM | 6MT | TEIN S Tech & Koni Sport | BMS Spacers 15mmF/10mmR
PiL is offline   Reply With Quote
Old 09-18-2013, 04:07 PM   #2
Moosecakes
My Ride: 02' SMG M3
Why? there's no point your spacers wont stick and if they do good spacers have a slot to slide a flat bladed screw driver in and pull them off. I just tap mine with a rubber dead blow hammer if it wont come off when I run them.. don't put that **** all over your brake and hub dude you don't need it.
Moosecakes is offline   Reply With Quote
Old 09-18-2013, 05:06 PM   #3
nofar
My Ride: 2006 M3 ZCP 6 SPEED
Thanks!
I spread anti-seize on the inner diameter of the spacer that fits to the wheel hub. That's it. This will allow it to rotate as necessary in order to align the wheel and studs up correctly to the wheel hub. Plus, many spacers have indentations for a flat-head screwdriver so you can "pry" them off later, if need by. I've had this for about two years now and no issue.
2006 M3 ZCP. Interlagos Blue on Dove Grey. 6 speed manual.
Eibach Pro-Kit / Koni externally adjustable F&R shocks / DDM Aluminum Pedals / BMW Performance Short Shift Kit / Clutch Delay Valve (CDV) removed / Painted reflectors / Stealth bulbs / Turner 15mm/10mm front/rear spacers.
nofar is offline   Reply With Quote
Old 09-19-2013, 12:15 AM   #4
rcsummers
My Ride: M3
^ this.
i put a small, small, small about on the part that will come in contact with the hub. makes them easier to adjust and line up.
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
