///M3 Forum
Old 09-19-2013, 12:30 PM   #1
///M3murray
My Ride: Bmw e46 M3
E46 M3 rear clunking noise please help!!!!!!
Can anybody tell me what this is! Could it be the rear subframe?!!!
https://www.facebook.com/photo.php?v...type=3&theater
///M3murray is offline   Reply With Quote
Old 09-19-2013, 12:46 PM   #2
cold m3
My Ride: E46 ///M3
http://www.m3support.net/thread/69/d...=1&scrollTo=92
Photos of My ///M3
cold m3 is offline   Reply With Quote
Old 09-19-2013, 01:02 PM   #3
///M3murray
My Ride: Bmw e46 M3
Thank you, is there anyway to post a vid on here straight from your i device ? So I can show you a vid of the clunk
Old 09-19-2013, 01:04 PM   #4
choxor
My Ride: JDM
Some clunk is normal. If you're worried that it may be the sub frame get it on a lift and have it inspected. Highly doubt we'll be able to tell anything from a cell phone video.
There are also updated differential bolts that reduce the clunk.
Old 09-19-2013, 01:08 PM   #5
///M3murray
My Ride: Bmw e46 M3
Thank you
Old 09-19-2013, 01:12 PM   #6
steven808
My Ride: 2004 BMW 330i ZHP
Re: E46 M3 rear clunking noise please help!!!!!!
I can't see your video, but I think I'm having similar problems right now too. I had a huge loud "clunk" sound too when I'd let off the gas. I have smg, not sure if that makes a difference.
steven808 is offline   Reply With Quote
Old 09-19-2013, 01:21 PM   #7
///M3murray
My Ride: Bmw e46 M3
I have smg as well, it's almost like a rattle from the rear suspension and I only noticed it when I pulled into garage, but how can I post a video on here?
Old 09-19-2013, 01:27 PM   #8
///M3murray
My Ride: Bmw e46 M3
Old 09-19-2013, 01:40 PM   #9
taylor192
My Ride: 2003.5 M3
Just take it to a shop. For $50-100 they'll inspect the suspension and subframe and give you a real answer rather than people guessing from videos.
Old 09-19-2013, 02:16 PM   #10
///M3murray
My Ride: Bmw e46 M3
Thanks everybody , it is the diff bushings
Old 09-22-2013, 04:04 PM   #11
pbm7
My Ride: e46
Its the cv joint on the back of the driveshaft it's worn you have to replace the whole driveshaft cause you can't get that separate.
Sent from my SAMSUNG-SGH-I747 using BimmerApp mobile app
pbm7 is offline   Reply With Quote
Old 10-04-2013, 05:04 PM   #12
PITT M3 RR
My Ride: E46 M3
Good lord don't jack your car up on the differential fins. use the subframe just in front of it. Youll crack the cooling fins right off!
UUC SSK / AFE STG1 Intake / AKG Red Motor mounts / AKG Red Tranny mounts / AKG Red Subframe bushings / AKG Red Differential bushings / AKG Red RTABS / TMS Subframe reinforcement / Custom in trunk subframe structural brace / Bilstein PSS10's / Ground control camber plates / Turner RSM
PITT M3 RR is offline   Reply With Quote
