///M3 Forum
Old 09-19-2013, 01:22 PM   #1
Alotaps
My Ride: E46 M3
Would I be able to run these tire sizes?
Considering my fronts are in good shape - I'm only buying rears because they're shot, (PSS'S). My tire sizes are stock right now. 225 in the front, 255 in the rear. Would I be okay if I ordered a set of 275's for the rear and keep the 225 in the front, or would that cause issues?
Alotaps is offline   Reply With Quote
Old 09-19-2013, 03:04 PM   #2
ME46SM
My Ride: '04 E46 M3
I'm running 275 in the rear without any issues and I have a lowered suspension on 19s. 275 should be fine
ME46SM is offline   Reply With Quote
Old 09-19-2013, 03:09 PM   #3
rcsummers
My Ride: M3
those are both fine.
but depending on your wheel size, the side wall ration would be different.
for 18's ---> 225/40/18 would be best in front, 275/35or30/18 rears (depending on how meaty of a side wall you want)
for 19's ---> 225/40/19 best in the front, and 275/35/19 rears.
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
Old 09-19-2013, 03:12 PM   #4
DSilk56
My Ride: M-3 Convertible
275's at the rear with 225's in front will really make your car understeer. The reason BMW went with the staggered set-up on the M3 was to keep oversteer in check by increasing grip in the rear as contrasted with the front. As it stands with the 255/225 rear/front split, the car is relatively neutral. Increasing the width of the rears by 20 mm will put you in a position where your front will begin to plow before the rear loses grip, just like a FWD set up.
DSilk56 is offline   Reply With Quote
Old 09-19-2013, 09:10 PM   #5
Alotaps
My Ride: E46 M3
I have OEM 19's. So this wouldn't be a good setup then? I really like the fat tires in the back - would 265/40 be okay for the rear, or should I just stay at 255?
Old 09-20-2013, 09:05 AM   #6
DSilk56
You can go to 275 section tires in back (or 265) as long as you increase the width of the front tires to either maintain the designed in differential, or (as many posters like to do) go to a fully square setup. Just remember that a fully square setup will result in oversteer. Also remember that increasing the width of your tires will also increase the rolling circumference of the wheel and tire package, and result in increased speedometer and odometer error. The 35 section width tires that you are proposing actually have a lower sidewall height, and will decrease your wheel/tire diameter by 1.2 centimeters. This isn't much, indeed the decrease in circumference is less than 1%, so this won't be a serious issue.
Old 09-20-2013, 12:41 PM   #7
khr0n1x
My Ride: 2004 CARBON BLACK M3
I have 235/35 19s in the front and 285/30 19's in the back
| 2004 E46 M3 Carbon Black | Black Interior |
| OEM Short Shift Kit | Depo LED Turn Signals |
| Angel Eye LED's | CSL M3 Style Carbon Splitters |
| VMR V710 Gunmetal Grey 19" |
| Agency Power V1 Exhaust |
khr0n1x is offline   Reply With Quote
