///M3 Forum
Old 09-22-2013, 12:15 AM   #1
othie
My Ride: m3
2002 m3 diff.. Help!!!!!!!
How much fluid and whats the best kind???
Every smg shifts feels like its been hit with a hammer???? Is that bad????
othie is offline   Reply With Quote
Old 09-22-2013, 04:09 AM   #2
Shonky
My Ride: 2004 E46 M3
BMW fluid is probably recommended. There is a special FM (friction modifier) version if your diff makes a grinding noise when doing sharp turns.
As for your problem it's highly unlikely that diff fluid will be the cause. Your other thread received a reply.
You've not provided very much info at all. Is that at full throttle? SMG shifts a full throttle are quite brutal particularly in S5, S6 etc.
Tried an SMG reset?
Shonky is offline   Reply With Quote
Old 09-22-2013, 04:27 AM   #3
othie
My Ride: m3
Re: 2002 m3 diff.. Help!!!!!!!
Well slow sharp turn the rear sound like its grinding.. Left and right.. And from a stop point lite acceration shift from 1st to 2nd gear i hear a loud noise from the rear...
