///M3 Forum
Old 09-22-2013, 03:39 PM   #1
pbm7
My Ride: e46
S54 vanos
Is it possible to replace the vanos without the special tools?
Sent from my SAMSUNG-SGH-I747 using BimmerApp mobile app
pbm7 is offline   Reply With Quote
Old 09-26-2013, 09:11 AM   #2
redrider423
My Ride: 2005 BMW M3 6MT Vert
S54 vanos
No. Spend the cash and get the tools. You'll thank your self later. You can remove and install the Vanos with out the cam bridge but I would not recommend it. The crankshaft locking pin is essential.
redrider423 is offline   Reply With Quote
Old 09-26-2013, 10:17 AM   #3
pbm7
My Ride: e46
Re: S54 vanos
So there's no way to actuat the vanos without the special tools? And I have the crank locking pin.
Old 09-26-2013, 10:50 AM   #4
///mteknikk
My Ride: 02 E46 M3
you need the crank tool and the actuators. also you need air to actuate the vanos. if not you will time the vanos wrong and you'll get a vanos code with poor performance. im a beemer tech so its really important to not try to take shortcuts.
///mteknikk is offline   Reply With Quote
Old 09-26-2013, 12:11 PM   #5
pbm7
My Ride: e46
Re: S54 vanos
The tools are expensive to actuat tge vanos even with my discount I'm also a beamer tech our shop doesn't have the ine to actuat the vani s or the one that goes on the vanos to supply air.is it possibly to get them from somewhere else or rent ?
Old 09-26-2013, 12:37 PM   #6
///mteknikk
My Ride: 02 E46 M3
you can always make one. its just power and ground for the soleniods. look at wiring diagram and see what the pins are for and have at it.
Old 09-26-2013, 03:05 PM   #7
pbm7
My Ride: e46
Re: S54 vanos
Hahah I was just think about that .would I still need the air ?
Old 09-26-2013, 03:46 PM   #8
///mteknikk
My Ride: 02 E46 M3
im sure you do.
Old 09-27-2013, 09:02 PM   #9
dafoe
My Ride: LSB M3
Hey OP, you need the locking PIN, and cam bridge. The actuators are not necessary. I've done many vanos overhauls successfully without the actuator... It's nice to have but not necessary... my two cents.
2001 M3, LSB 6spd, purchased 6/09 with 25K miles.
Mods: Coyne Performance built ///M3
dafoe is offline   Reply With Quote
Old 09-28-2013, 08:37 AM   #10
pbm7
My Ride: e46
Re: S54 vanos
Actually the updated repair manual says you don't need the cam bridge anymore
Old 09-29-2013, 10:54 AM   #11
intelone
My Ride: e46 M3
OP you need to explain this more! What updated service manual are you talking about? Once you unbolt the hub(s) or remove the splined shaft you will need the cam bridge and pin combo. Anything else you can probably get away without, but I'm not sure.
You say vanos like its a single component. Then you drop this on us, like you're a vanos veteran. I can't take you seriously.
intelone is offline   Reply With Quote
Old 09-29-2013, 11:04 AM   #12
Alroy
My Ride: 2003 M3 SMG CWPkg.
Start by replacing the solenoid pack to see if that solves your problem before ripping open the VANOS hub.
...and if it is deemed necessary that the hub will have to come off, get the timing tool at bimmertoolrental.com.
Alroy is offline   Reply With Quote
Old 09-29-2013, 02:01 PM   #13
pbm7
My Ride: e46
Re: S54 vanos
I'm not removing the hubs or spline shafts just the vanos unit. That's why I don't need the cam bridge.
Old 09-29-2013, 02:15 PM   #14
intelone
My Ride: e46 M3
Ah yes clarity. Why not replace the cam bolts while you're in there? Or even take a look at the timing chain guide that's been known to break? Are you going in there just to replace the oil pump disc and seals while negating the other stuff just to avoid buying/renting a cam bridge? Do it all and right the first time.
