///M3 Forum
Old 09-22-2013, 08:30 PM   #1
e90dima
My Ride: e92
Want to buy a high mileage m3
I'm looking at an 03 m3 with 178k miles 6speed. Seems to be in good working order. How long can these engines last?
e90dima is offline   Reply With Quote
Old 09-22-2013, 08:39 PM   #2
ik47
My Ride: bmw m3 e46
There is many threads like that . Just use search .about ur question ,it all depends how people take care of it before .so if you will take care of it it will go another 100k
ik47 is offline   Reply With Quote
Old 09-22-2013, 08:41 PM   #3
JapanRot325ci
My Ride: 04 E46
depends on the previous owner maintenance history. maintenance > anything. a car can last you a whole life time if you do maintenance. one thing to look for is their subframes, they're prone to crack
JapanRot325ci is offline   Reply With Quote
Old 09-22-2013, 08:51 PM   #4
e90dima
My Ride: e92
I'm just worried about the strength and longetivity of the s54 engine. The seller has very good records. Can the engine last another 100k?
Old 09-22-2013, 08:53 PM   #5
farmdog
My Ride: Food Truck
What's the asking price?
farmdog is offline   Reply With Quote
Old 09-22-2013, 08:53 PM   #6
inlinesicks
My Ride: E46, Jeep, Subaru
Have a compression test done, that will give you an idea of the overall health of the engine.
inlinesicks is offline   Reply With Quote
Old 09-22-2013, 08:54 PM   #7
e90dima
My Ride: e92
8k
Old 09-22-2013, 09:13 PM   #8
inlinesicks
Originally Posted by e90dima View Post
8k
Go buy it now.
Old 09-22-2013, 09:17 PM   #9
ross1998
My Ride: 2006 G35 Coupe
8k
Buy it now if he has good repair records
ross1998 is offline   Reply With Quote
Old 09-22-2013, 09:32 PM   #10
MercForHire
My Ride: M235i 6MT
probably has broken subframe
Old 09-22-2013, 09:46 PM   #11
e90dima
My Ride: e92
The subframe looks good, and not broken yet. I drove it, and i think it needs a new clutch which the owner said it does but it's not terrible. the engine is perfect, and runs great with no check engine light. Has anyone driven and m3 to 200k+ miles on the original engine.
Old 09-22-2013, 09:49 PM   #12
e90dima
My Ride: e92
ID:	527729Click image for larger version
ID:	527730Click image for larger version
ID:	527731Click image for larger version
Old 09-22-2013, 09:54 PM   #13
zheka130
My Ride: 2004 ZHP
seems like a very good deal
zheka130 is offline   Reply With Quote
Old 09-22-2013, 10:03 PM   #14
dwtaylorpdx
My Ride: 2005 330xi
Compression and LEAKDOWN!You need both to know the real story..
Cheers
dwtaylorpdx is offline   Reply With Quote
Old 09-22-2013, 10:10 PM   #15
e90dima
My Ride: e92
Cheers
Well, the owner said he doesn't want to deal with changing the clutch, and it's due for a cooling system overhaul. If there was something wrong with the engine, wouldn't it run bad, smoke, rough idle, tick, through engine light at high revs, make weird noise at high revs, have low power? The car has none of these symptoms.
Anyways how much do mechanic usually charge for compression leakdown test?
Old 09-22-2013, 10:33 PM   #16
jcns
My Ride: California
M3 badge not in the right place. Maybe due to accident.
Valve check records would be important since they need to be inspected and adjusted as needed every 30K miles.
jcns is offline   Reply With Quote
Old 09-22-2013, 11:19 PM   #17
e90dima
My Ride: e92
Thanks jcn, I'm going to run a carfax before I hand over the cash.
Old 09-23-2013, 07:24 AM   #18
helmutm3
My Ride: 04 m3
Thats a good price, since the car has 178k I think the price is exactly where it should be. Do not touch this car without a PPI, however. The rear diff has to come out to check the subframe for cracks. As far as I remember the PPI also includes the leakdown test. You dont want an M3 with 180k that will end up costing you 14k after repairs. I would only buy this one if it was immaculate and in need of very little work.
helmutm3 is offline   Reply With Quote
Old 09-23-2013, 08:06 AM   #19
choxor
My Ride: JDM
It's not a jug of milk. It doesn't have an expiration date. How long the engine will last depends on how it was treated. Get a PPI done.
Old 09-24-2013, 07:55 PM   #20
e90dima
My Ride: e92
Okay, soo I just check it out, and it actually not too bad. It may have a blown headgasket, because I revved the **** out of and there was a little bit of very very very light steam, from the exhaust. But there is no mixing of fluids, and it has been raining a lot lately. The fenders are fading a little bit, and the clutch probably needs replacement in the next 10k miles. The owner said he would let it go for 5k.
