Old 09-23-2013, 02:51 PM   #1
brianacampa
My Ride: 2006 330CI Convertib
Pass Key for pairing bluetooth
I just bought a 2006 330 CI Convertible and want to pair my iphone. I need to find the pass key. Unfortunately the documentation for the phone operation was missing. I found the instructions on how to pair the phone but need the pass key and do not know how to find it
brianacampa is offline   Reply With Quote
Old 09-23-2013, 02:53 PM   #2
Zell
Zell's Avatar
My Ride: so turbo wow
I think it might be on the TCU as well.
Old 09-23-2013, 03:09 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
If you have a 2006 E46 convertible with the BMW Assist/SOS button on the mirror, it should have Bluetooth.
Contrary to ANYTHING you rear, there is no button to push for pairing the Bluetooth in the car.
The ULF/TCU module should have the passkey on it. You might try the last 4 of the VIN, but I cannot say this will work.
I have had my 2006 for 4 years and I have never located the ULF/TCU module, it is likely in the trunk, but I did not want to pull all the lining off to access it.
The easy way is to just buy the BMW Scanner 1.4.0 software from www.xcar360.com and then you can read the Bluetooth passkey and also program your windows and top to close with your keyfob and do some other things.
You could probably search the net for where the ULF/TCU is located in the convertible.
One piece of useful information to note, when you are looking for parts other than the dealer, tell EVERYONE it is a 2005 not a 2006. Most parts people and parts applications do not realized the coupe and convertible in 2006 is an E46, they always think these are E9x.
Very common for people to get the 2006 confused for an E9x chassis.
Old 09-23-2013, 03:56 PM   #4
ragtop69
My Ride: 2004 bmw 330 conv.
The tcu is mounted against the rear seat on the left side of the trunk. I believe the passcode is printed on it. It is easy to get too, just pull out the left side and rear seat trim panels
ragtop69 is offline   Reply With Quote
Old 09-23-2013, 05:28 PM   #5
PKR
My Ride: '04 330Cic
Right, its against the rear seat but the HF (handsfree) code is hidden on the backside so you may need to loosen it or remove it.
PKR is offline   Reply With Quote
Old 09-23-2013, 08:51 PM   #6
ragtop69
I think you are right, you have to unbolt it to see it. I retrofitted bluetooth so I wrote it number down before I installed it
Old 09-23-2013, 10:32 PM   #7
brianacampa
I'll give that a try. What does TCU stand for?
Old 09-24-2013, 07:39 AM   #8
bimmernut3
My Ride: '05 330cic, '01 540i
Here's a picture of the TCU (Telephone communications unit) or something like that. The numbers after the "PK" are the "PASS KEY" numbers. Hope this helps.
'05 330ci
[IMG][/IMG]
bimmernut3 is offline   Reply With Quote
Old 09-24-2013, 08:49 AM   #9
brianacampa
thanks
Old 09-25-2013, 05:43 PM   #10
alpine003
My Ride: BMW
Fwiw, PA Scanner also lets you program your own passkey. This is what I did to a more easy to remember one in case I get in the same situation in the future.
alpine003 is offline   Reply With Quote
Old 09-25-2013, 06:47 PM   #11
bimmernut3
What & where "PA scanner" did you buy?
'05 330ci
[IMG][/IMG]
Old 09-25-2013, 07:01 PM   #12
///M Protocol
Banned User
My Ride: i3
there is a passkey sticker on your tcu (actual it is your ULF). your telephone control/communication unit is located in the trunk. on the rear driver side.
I have a pairing button underneath my arm rest and it is required for me to pair my phone initially.
///M Protocol is offline   Reply With Quote
passkey, phone
