Sponsored by BimmerWorld
Old 09-23-2013, 08:12 PM   #1
Phoenix330ci
My Ride: 04 330Ci Convertible
FCAB's - POLY or Meyle HD
Ok I had original FCAB's which at some point I switched to the Power Flex Poly which came preassembled and lubed with the copper grease. Reason is because the old ones gave out after 50K. Now it looks like it is time to replace the Power Flex ones. I have probably 80K on those. They are starting to squeak a lot more, the drivers side one, the inner part has actually slid forward on the LCA and the passenger one I can grab the LCA and see movement in the FCAB when the car is jacked up. So the hole where the LCA goes into the FCAB looks to now being stretched larger (probably why the driver side one slid forward) Noticed all of this after hearing a little bit of a banging going on in the front end.
So I know I have to replace them. I noticed no real difference from the rubber to the poly the first time. (only thing being I just got like 50% more life out of the poly ones.)
Anybody have the Meyle HD ones? Would anyone recommend going back to poly? The slight creaking of the poly (even with the copper grease) is a little annoying, more on cooler days. How does the Meyle HD hold up?
I'm leaning on going back to rubber.
Phoenix330ci is offline   Reply With Quote
Old 09-23-2013, 08:19 PM   #2
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
i noticed a big difference when going from rubber oem to poly. car feels a little snappier. granted, my rubber ones werent new but they definitely had life left.
i'd say go with rubber if you had bad squeaking with the poly. mine don't squeak yet but i haven't had them long.
Old 09-23-2013, 08:21 PM   #3
hanna
My Ride: BMW 328i
I just installed Meyle HD bushings last week. Do not like them. No more shuddering of the steering wheel when braking sharply and everuthing feels tight but HD are causing annoying vibration of the steering wheel at 60-65 mph. Lemforder for me next time.
hanna is offline   Reply With Quote
Old 09-23-2013, 08:22 PM   #4
peytonracer4
:D
My Ride: '00 328i
i don't think that's due to the bushings. that's something else.
Old 09-23-2013, 08:23 PM   #5
hanna
My Ride: BMW 328i
wrong. research. "something else" is new.
Old 09-23-2013, 08:24 PM   #6
peytonracer4
:D
My Ride: '00 328i
what do you mean research? vibration at certain speeds is almost impossible to be caused by bushings. that would be a balancing/wheel bearing/ball joint thing.
Old 09-23-2013, 08:27 PM   #7
biMMer4.4i
My Ride: 2002 330i
I think powerflex fcabs have a lifetime warranty, at least I think that's what I read when I bought mine. I'm surprised yours don't?
biMMer4.4i is offline   Reply With Quote
Old 09-23-2013, 08:41 PM   #8
MadLow
My Ride: 2004 330CI
your control arm ball joints are shot, u are just noticing that now since u changed your fcab bushings
MadLow is offline   Reply With Quote
Old 09-23-2013, 08:44 PM   #9
dreyo27
My Ride: 2001 325ci
Originally Posted by biMMer4.4i View Post
I think powerflex fcabs have a lifetime warranty, at least I think that's why I read when I bought mine.
Yep go with these and they dont squeek. I had myle HD and they last me an avarage of 25k but I am a spirited driver.
dreyo27 is offline   Reply With Quote
Old 09-24-2013, 02:48 AM   #10
My Ride: 2016 Lexus
Peytonracer is correct. Your car needs maintenance if its vibrating, Hanna.
My car has Meyle HD bushings and my car's steering is smooth and accurate as a GPS-guided missile.
Sorry to burst your bubble. Stick around a little while to see the info gathered on the steering. It's all been discussed in suspension
Old 09-24-2013, 04:23 AM   #11
TerraPhantm
My Ride: M3 & ZHP
Stiff bushings can make road imperfections more apparent, and it's plausible that those can cause vibrations (that are always there, but only noticeable at certain speeds).
Or it can be unrelated. I had some vibrations that I've been chasing for a while but just couldn't figure it out (seemed wheel related, but it was not bent). I finally took it to an auto-x this weekend, and I swear it's gone. I'm thinking I had a flat spot on my tire and basically burned it round again lol.
Well if I'm honest, there are still some vibrations once you get to 110+, but I don't think there's much you can do to avoid that if you don't have autobahn quality roads
Old 09-24-2013, 08:00 AM   #12
SoloII///M
My Ride: Many
I had the Meyle HD ones on my car and was not impressed. After 40,000 miles of use I started to get vibration under braking and some imprecise steering.
I also tried the powerflex ones on my competition car, and they disintegrated after three events. So I will never go back to those bushings.
I replaced them this weekend with MZ4 bushings, which are made of solid rubber and are offset for about a half degree more positive caster. They tightened up the front end, improved steering feel and eliminated all my steering wheel shake. Best part, they are cheap!
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 09-24-2013, 11:32 AM   #13
howie3
My Ride: 2001 325i
I just replaced my cab with Meyle HD. Feels good around town now but at higher speeds on highway(60mph) I get vibration in steering. Any suggestions. Do I need an alignment after changing them.
howie3 is offline   Reply With Quote
Old 09-24-2013, 12:05 PM   #14
hummer
My Ride: 2001 330CI
Old 09-24-2013, 12:27 PM   #15
howie3
My Ride: 2001 325i
I'm not sure what you mean by your reply
Old 09-24-2013, 12:32 PM   #16
mr ilia
My Ride: 2004 BMW 325i 5spd
You should not need alignment after replacing FCAB.
---- My Beemer history ----
2004 BMW 325i sedan - Schwarz II
1998 BMW 323i coupe - Lazurblau
2004 BMW 325ci - Sapphire Black
1991 BMW 318i sedan - Lazurblau
2001 BMW 330i sedan (Auto) - Japanrot
http://forum.e46fanatics.com/signaturepics/sigpic288773_1.gif
mr ilia is offline   Reply With Quote
Old 09-24-2013, 12:36 PM   #17
hanna
My Ride: BMW 328i
Same thing here.
Old 09-24-2013, 12:40 PM   #18
hanna
My Ride: BMW 328i
Thank you!
I read that you fixed that vibration by switching to Lemforder fcabs. Do you still think this is the cause?
Old 09-24-2013, 01:29 PM   #19
howie3
My Ride: 2001 325i
I talked to my mechanic and he said it's very likely a tire balance issue. the old FCAB that had play, were absorbing the vibration before. I will try that first
Old 09-24-2013, 01:29 PM   #20
My Ride: 2016 Lexus
Thank you!
don't get "vibration" mixed up with road feel. if you are getting an unnatural shimmy, it's not your control arm bushings. if your front end is immaculate, even having solid spherical CABs won't cause a shimmy. Things vibrate at the speeds you describe (or any speed for that matter) when something is broken or out of balance.
