Old 09-24-2013, 10:04 PM   #1
Nerdy46
My Ride: 328i
Maintenance leads to new exhaust, sounds amazing!
Well I recently caught up on some much needed fixes. Replaced the clutch, pivot ball, detent pins, both control arms, trans mounts, flex disk, CSB, fixed a chunk out of a wheel, and new air filter. Well I hit a lot of problems. Exhaust was frozen on. I cut it off and replaced it with something unique.
Custom y pipe to a 3ft magnaflow glasspack followed by a vibrant stealth. Sounds nice and deep.
After these fixes the car feels better then ever.
Daily: 1999 328i (202k)- Sport and winter package, 5speed, Jet Black, hellbeige, e60 Short throw, cross drilled rotors, koni, H&R, ASA AR1, Vibrant stealth, basslink
Track: 1995 Mustang GT (230k)- 306ci, 5 speed, MGW shifter, Trickflow Heads, Trickflow intake, street cam, shaved and tucked engine bay, slammed, 1 3/4'' long tubes, tuned with moates.
On the Water: 7' Boneyard Retro Quad Fish
Nerdy46 is offline   Reply With Quote
Old 09-24-2013, 10:10 PM   #2
Nerdy46
My Ride: 328i
Next weekend its rtabs and who knows
Old 09-24-2013, 10:18 PM   #3
taveet330i
My Ride: Jet Black 2002 330i
Re: Maintenance leads to new exhaust, sounds amazing!
Haha so you were able to justify getting one. Keep up the upgrades and always make sure to keep the mantainance in mind
[bimmerapp]
_______________
Dedication
2002 Jet Black 330i|ZPP|Hellbeige interior|Carbon Fiber Interior Trim|Alzor 703 CSL Reps|Custom Flowmaster Catback Exhaust|LED Halo Rings|Black ECSTuning Kidney Grilles|Eonon D5150|
taveet330i is offline   Reply With Quote
Old 09-24-2013, 10:21 PM   #4
Nerdy46
My Ride: 328i
I had the vibrant. But figured while I was at it I do something different. I had to ditch the stock mounts and cut the brackets. I'm going to weld up some new cross braces soon. It was hard to fit a 4" od glasspack under the car while keeping ground clearance
Old 09-24-2013, 10:24 PM   #5
wildirish317
My Ride: 2004 325Ci vert
Post a vid with the sound.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 09-24-2013, 10:41 PM   #6
Nerdy46
My Ride: 328i
Here ya go:
http://s1272.photobucket.com/albums/...ps238d1721.mp4
Old 09-25-2013, 09:33 AM   #7
Nerdy46
My Ride: 328i
I should be able to take some more tonight
Old 09-25-2013, 12:03 PM   #8
wildirish317
A drive by at 4500 to 5500 rpm would be good.
Old 09-25-2013, 06:14 PM   #9
Nerdy46
My Ride: 328i
It will be in first speed limits are a max of 55 or 60 around here and I'm on stock gears.
Old 09-25-2013, 09:01 PM   #10
Airborne82id
My Ride: 330CI
How much did you spend on the clutch? @ what miles?
I'm at around 150K and clutch feels good so far ...
Airborne82id is offline   Reply With Quote
Old 09-25-2013, 09:33 PM   #11
wildirish317
Sorry. I have a 3.46 diff, and redline at around 55 mph in second. Do it in first gear.
Old 09-25-2013, 09:59 PM   #12
Nerdy46
My Ride: 328i
$160 214k
