Old 09-24-2013, 10:33 PM   #1
cheps
My Ride: 2004 330Ci
Aux fan problems
My aux fan only runs when the AC is turned on. If the AC isn't on I can smell the engine getting hot. Is this a problem with the fan electronics, the thermostat, or something else.
thanks scott
cheps is offline   Reply With Quote
Old 09-25-2013, 04:14 AM   #2
eneka
My Ride: 2003 325i
smell?
eneka is offline   Reply With Quote
Old 09-25-2013, 10:06 AM   #3
cheps
My Ride: 2004 330Ci
Originally Posted by eneka View Post
smell?
like hot burnt oil
Old 09-25-2013, 10:29 AM   #4
scottjoh
My Ride: '99 323i & '02 540i
Aux fan problems
Originally Posted by cheps View Post
like hot burnt oil
Valve cover gasket leaking onto the exhaust manifold.
I believe the push fan only comes on when the A/C is on and the pull fan is thermostatic controlled by the DME based on coolant temperature (assuming it's electric). I could be wrong, I'm just assuming.
scottjoh is offline   Reply With Quote
Old 09-25-2013, 03:13 PM   #5
cheps
My Ride: 2004 330Ci
I have a coupe which only has the one fan.
Old 09-25-2013, 04:33 PM   #6
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
does the engine actually get hot? i.e. temperature gauge?
Probably just burning some oil.
Schlag96 is offline   Reply With Quote
Old 09-25-2013, 05:22 PM   #7
Yewzer B Lewzer
My Ride: 2003 325i
Aux fan problems
As said. The smell is probably VCG leak, not engine running hot.
The aux fan will only come on when the AC is on and/or when the mechanical fan is not enough to keep the temp down. If all is running properly the aux fan will only come on after extended periods of idle in hot weather (unless the AC is on)
^^Blue Ridge Parkway^^ '03 325i. '74 Jeep CJ-5. '93 Sailfish 170XL. '12 Westside SS Longboard. One of these four are sure to be running at any given point in time.
Yewzer B Lewzer is offline   Reply With Quote
Old 09-25-2013, 09:14 PM   #8
cheps
My Ride: 2004 330Ci
The temp gauge stays in the middle all the time. If I have the AC on, the engine doesn't smell hot (like burnt oil). When I have the AC off the fan doesn't run and the engine smells hot. Am I to assume the VCG leak/smell is simply being blown away by the AC fan?
Old 09-25-2013, 09:21 PM   #9
lszlszx
My Ride: 1.8T, XC70
How many fans you have depends on whether the transmission is automatic, or manual, not whether it's coupe, or sedan.
If you only have one fan, your car is a stick shift. (unless someone has done a fan swap)
Learn to unlock the OBC hidden functions to monitor the actual coolant temperature, because the gauge is buffered and inaccurate.
That said, if the gauge stays in the center, the car doesn't overheat.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
