Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > UK
UK
Have you seen another BMW while driving around in your area? Find other members from your area in the E46Fanatics Garage HERE
Old 09-28-2013, 07:50 AM   #1
Ibby_c
My Ride: 330CI
Help!!! ignition switch from a e46 2005 330ci
HI all
does anyone know how to remove the ignition switch from a e46 2005 330ci
Ibby_c is offline   Reply With Quote
Old 06-06-2014, 02:54 PM   #2
alan53
My Ride: bmw E46 330ci
Send a message via Yahoo to alan53
if you want to remove the barrel? well from memory works on E36 , put the key in,you will need the key,look at the part the key turns do you see a tiny hole ? 1/2mm well jam a longish straight strong pin i used an allen key .i think you then turn the key keep pushing the pin and pull on the key and the barrel pops out ! should work if you see the tiny hole, its simple but fiddly, good luck
alan53 is online now   Reply With Quote
