E46 Convertible
Old 09-29-2013, 01:47 PM   #1
Mtype
My Ride: E46 m3
Soft top not locking properly
I have an issue with the top not locking all the way with the windshield on the passenger side, thus leaving a bit of an air pocket. Water gets in when it rains and it also rattles against the windshield and windows quite a bit when I go over bumps. Has anyone had these issues and if so, what is the solution. The drivers side closes just fine. Thanks guys
Mtype is offline   Reply With Quote
Old 09-29-2013, 02:54 PM   #2
taylor192
My Ride: 2003.5 M3
Re: Soft top not locking properly
The passenger latch is probably broken. Address this asap as if the drivers lock breaks when the top is closed you'll have to cut the cover to access the latches.
There's a bunch of recent threads about broken latches, search.
Old 09-29-2013, 05:05 PM   #3
Mtype
My Ride: E46 m3
thanks Taylor. It took me a while to find threads that referred specifically to the latches that connect to the windshield vs. the rear compartment. It looks like step #1 for me would be to see if I can lock it via the torx screw by the mirror. Will try that now.
Old 10-06-2013, 12:04 AM   #4
237_330ci
My Ride: 04-caddy-ext
Windshield latch
Mine are closed but not on the windshield, any ideas how to open them?
237_330ci is offline   Reply With Quote
Old 10-06-2013, 09:05 PM   #5
CombatWombat
My Ride: 330cic
Please read what Taylor wrote again. If you lock it down manually there is a chance you won't be able to open it again and you'll have to cut up your car like I did.
Open the top and remove the plastic piece that's covering the motor and both latches. Address the issue with the latch, and then close it up.
CombatWombat is offline   Reply With Quote
Old 10-06-2013, 09:20 PM   #6
Mtype
My Ride: E46 m3
Yes, I figured that out upon reading more threads. It looks like I will need to replace the whole latch assembly. this particular task is outside of my domain so I am fully prepared to take it up the @$$ prison style and bring it to the dealer. I was quoted $450 for the part and $150 for labor
