E46 Convertible
Old 06-01-2014, 09:42 AM   #21
330ci in MS
My Ride: 2003 330ci
Excellent description / pics for latch access
The description and pictures helped greatly in resolving the issue of the broken latches for our 330ci convertible. Your descriptions/pics, along with the fix action in (http://forum.e46fanatics.com/showthread.php?t=1036813) allowed me to repair the top function...very nice. I attempted the epoxy fix but either due to the operations pressure or unable to fully clean the area it would not hold during manual closing / opening stress testing. Drilled two holes in both plastic/latch assemblies and all is good. Thanks again!
330ci in MS is offline   Reply With Quote
Old 06-01-2014, 12:48 PM   #22
comova
My Ride: Silver 325Cic
Awesome!
"The problem with the designated driver program, it's not a desirable job, but if you ever get sucked into doing it, have fun with it. At the end of the night, drop them off at the wrong house." -Jeff Foxworthy
comova is offline   Reply With Quote
Old 07-28-2014, 10:53 AM   #23
taylor192
My Ride: 2003.5 M3
I tackled this yesterday as preventative maintenance. I used 2 bolts and plastic weld (similar to epoxy putty) to strengthen the part, and took lots of photos.
I'd like to have a concise single post with detailed photos of how:
- the latch fails
- to check if your latch is failing (it is possible without removing the cover!)
- to remove the cover
- to remove the latches
- to strengthen the latches
I'm probably going to create a new thread, since this is not my thread and I cannot edit the first post.
Old 07-28-2014, 07:19 PM   #24
avneet
My Ride: 2001 330ci Vert
- the latch fails
Definitely do a new thread. I bet yours will be clearer and better. Better to have it separate and let it slowly replace this one. I just did this as there was no thread to refer to beforehand.
avneet is offline   Reply With Quote
Old 07-29-2014, 11:01 AM   #25
taylor192
My Ride: 2003.5 M3
This is an excellent DIY to get at the latches! Just needs an update with a better way to fix the latches.
Do you mind if I "steal" some of your photos? I'd like to upload them to my photobucket "DIY" folder so they remain with the rest of the photos I'll add.
Thanks in advance!
Old 07-29-2014, 08:31 PM   #26
avneet
Thanks in advance!
Don't mind at all. Look forward to your diy.
Old 08-03-2014, 07:49 PM   #27
kfur
My Ride: 2005 325Ci
Glad I found this thread
Was looking at a new assy $500-600 Part #:54-34-7-031-361-M9. Left one failed and used the information from this post to repair mine. Anyone have some time under the repair? "Is it still holding?
ID:	567802   Click image for larger version
kfur is offline   Reply With Quote
Old 08-03-2014, 09:28 PM   #28
taylor192
My Ride: 2003.5 M3
Check out my DIY for a better way to reinforce the latch.
http://forum.e46fanatics.com/showthread.php?t=1047072
Cause yours sheared in half I think you need to reinforce it even more than you did. You'll notice I used plastic putty to fill in and build up the part between the threaded half and metal bar half.
That plastic putty is tough! Plus it's much easier to work with to build up the part.
Old 08-04-2014, 07:49 PM   #29
avneet
I agree with Taylor. That fact that it fully separated means it needs a lot more reinforcement than mine (that was only cracking). Mine hasn't had any issues all summer, but I can't compare it to a full break like that.
Old 11-27-2016, 09:04 AM   #30
BUDGET76
My Ride: 03' M3 & 95' 330TI
bumping an old thread, but this may help someone in the future.
I helped dad figure out this was his issue with his e46 vert a couple months ago. He made the repair, but never put the cover panel back on.
I found that you DO NOT need to fully remove the screws on the 'interior' of the cloth/top area to remove the panel. You simply need to back them out most of the way. The panel is sheetmetal and is just pinched by the screws when you tighten down, and there are slits, not holes, in the panel to allow it to slide down and be removed.
The panel itself is held in by the torx screws mentioned in the original post + the 2 phillips. After you loosen the (I think 5) cloth screws and remove all the torx, the only thing holding it in place is wetherstripping. Likely the two strips on the sides, those are the tightest areas.
'03 M3. Titanium Silver/Black. Bilstein PSS10, 19" VMR 710, UUC SSK, UUC LWT clutch/flywheel, UUC catback, ///Avin Avant2.
'02 330XI daily
SOLD'95 S50 TI, bad weather beater, tow rig
BUDGET76 is offline   Reply With Quote
Old 01-29-2017, 03:43 PM   #31
Kmck
My Ride: 2006 325 CI
Broken convert roof lockdowns
My plastic pieces disentergrated when the dealer tore it down.
where do I find the plastic piece to replace or do I need to order the whole mechanism?
Kmck is offline   Reply With Quote
Old 01-29-2017, 03:45 PM   #32
Kmck
Not real up to speed on this site.
Ill do it again
My plastic pieces disintergrated when the dealer opene, they all fell out.
Wher do I order more plastic peics or do I need to order the whole mechanism?
Old 01-29-2017, 03:48 PM   #33
Kmck
I have not tore it down yet. But would like to have the parts ready before I tear down.
Old 01-29-2017, 03:49 PM   #34
Kmck
