E46 Convertible
Old 10-05-2013, 10:30 PM   #1
237_330ci
My Ride: 04-caddy-ext
Windshield top latches....
How do you open these...if you used the emergency top closing procedure , and the latches closed before the top was to the windshield.?
237_330ci is offline   Reply With Quote
Old 10-06-2013, 12:19 AM   #2
avneet
My Ride: 2001 330ci Vert
There is a tab you pop out from the center of the plastic enclosure where the locking motor is. You turn the hex in there to unlock the latches. The plastic enclosure with the tab is on the inside of the convertible top (above your head in the center).
avneet is offline   Reply With Quote
Old 10-06-2013, 12:43 PM   #3
237_330ci
I tried that... Nothing happened
Old 10-06-2013, 01:15 PM   #4
taylor192
My Ride: 2003.5 M3
Re: Windshield top latches....
Then your latches are broken. There are lots of recent threads about the latches and latch motor breaking, search don't pm me.
Old 10-06-2013, 01:15 PM   #5
avneet
Does the hex just keep spinning, or does it eventually stop as you spin it? If it keeps spinning, a gear in the motor may be broken. http://forum.e46fanatics.com/showthread.php?t=1004823
Old 10-06-2013, 08:02 PM   #6
CombatWombat
My Ride: 330cic
Yep, make sure you're turning it the correct way.
If this piece falls out in your hand, then there is likely a gear broken inside the motor:
If it keeps turning and nothing appears to happen, then the plastic piece on the latch itself is probably broken.
Either way you'll have to bust out the Sawzall like I did in my thread above. Cost me ~$450 to do it myself. If the latch was broken also it would have cost me almost $1000 to do this. A shop would likely charge a minimum of $1500.
CombatWombat is offline   Reply With Quote
Old 10-17-2013, 01:02 PM   #7
southncomft
My Ride: 2000 323 ci
Since you did it yourself, can you tell me where you got the instructions? I got that $1500 quote too. I want to give it a shot. Is it a complicated process?
Sent from my LG-P769 using BimmerApp mobile app
southncomft is offline   Reply With Quote
Old 10-17-2013, 07:21 PM   #8
avneet
Instructions to get to stuck latches:
http://forum.e46fanatics.com/showpos...11&postcount=7
Instructions to get to the latches otherwise:
http://forum.e46fanatics.com/showthread.php?t=1008202
