Old 03-02-2014, 06:51 PM   #121
str8dum1
My Ride: VQ38DETT
without an experienced tuner, how do you know that you have the SMG tables setup properly? Is Garth tuning the car?
VQ38DETT on twin 6262 with ProEFI128
str8dum1 is offline   Reply With Quote
Old 03-02-2014, 07:07 PM   #122
mdrobnak
My Ride: 04 330i SMG TT STG1
This is not my first rodeo. At one point in time I was using SCT and tuning local Mustangs...the items I've gone into so far have not been much more advanced then that, save for this torque reduction stuff.
If the documentation was better, this might be a non-issue. The documentation is terrible, plain and simple. Without accurate definitions, of course it's going to be trial and error...
Garth will be tuning E85, after the car is prepared, if we get to that point.
-Matt
2004 330i with Technique Tuning Stage 1 Kit, UUC Twin Disc Clutch + FW Kit, Walbro 400 Fuel Pump, Aeromotive FPR, Modified Return Lines, E36 Fuel Filter, Ethanol Content Sensor, 550i Clutch Actuator, Lengthened actuator rod, modified exhaust, and FX-R projectors.
93 Octane - 8.5 PSI : 309RWHP on a Superflow / 3XXRWHP on a DynoJet
E85 - ? PSI : ???RWHP on a DynoJet
First SSG MoTeC M150 Powered 330
mdrobnak is offline   Reply With Quote
Old 03-05-2014, 10:42 PM   #123
mdrobnak
I'm closing in on the 'nope, not gonna happen' point - I have done what Jason's said in my thread on the ProEFI site, and while I've reduced the slip to 0 during normal operation, it does not seem to trigger...and I'm running out of patience.
I've sent out pleas of help to one dealer and one sort-of dealer, and waiting for them to get back to me. If nothing comes of that, then I'm going to put the ProEFI up for sale.
The unit works, just not for me and my transmission.
-Matt
Old 03-06-2014, 12:20 AM   #124
Davew
My Ride: 2004 330ci Msport
Pin J1A25 on the pro efi, two micro switches on the gear selector for up and down to a relay, and maybe an electro magnetic switch mounted on the clutch actuator, all 12 volt supply inline. Will force a traction control request at gear change. Might this work??? Also wondering if you have connected wheel speeds from dsc, I wonder if the pro efi needs driven and un driven wheel speed seperate to can to operate the torque reduction so it knows where it stands. Out on a limb on this, but really hoping you don't give up with on this stage of the project.
Davew is offline   Reply With Quote
Old 03-07-2014, 09:26 AM   #125
mdrobnak
I have non-driven and driven wheel speeds via CAN. They are correct.
I had to fudge the gear ratios up a bit higher to make the slip % go to zero.
Still does not trigger.
CAN based torque reduction requests will not be implemented for the BMW. The support is there, but I already asked and the work will not be done.
I have given my last tune + log to two excellent tuners. If either of them can get it working, I'll keep going, but I'm not particularly hopeful. In all likelihood I will be uninstalling the unit and putting it up for sale in the next week or so.
-Matt
Old 03-07-2014, 09:26 AM   #126
mdrobnak
(Double post, yay T-Mobile)
-Matt
Old 03-11-2014, 11:39 AM   #127
str8dum1
My Ride: VQ38DETT
hows it going?
Old 03-11-2014, 05:28 PM   #128
mdrobnak
No update on the ProEFI front as of yet. I assume both are busy with the stuff in Texas.
-Matt
Old 03-18-2014, 05:20 PM   #129
diablorojo
My Ride: Supercharged 330i
Any update?!
Started ESS...ended CUSTOM!
diablorojo is offline   Reply With Quote
Old 03-18-2014, 06:12 PM   #130
mdrobnak
Nothing from either party.
-Matt
Old 03-21-2014, 09:17 AM   #131
mdrobnak
I wrote Garth yesterday, and the bottom line is that he also thinks it should be working, and would have to see the car in person to figure out what's going on.
At this point I'm just cleaning up some things like getting Decel Fuel Shutoff to work nicely (which involves working on the DeltaTPS stuff a bit), but as soon as I get my car to MaxPSI, I'll have them remove the O2 sensor and I'm going back to the DME.
Plans after that are not set in stone.
-Matt
Old 03-21-2014, 09:25 AM   #132
str8dum1
My Ride: VQ38DETT
FWIW, decel cutoff doesnt involve delta tps. unless you meant the acceleration enrichment tables. And those you do not touch until you have a complete VE map 100% dialed in.
Old 03-21-2014, 09:30 AM   #133
mdrobnak
Being more clear...cleaning up the transition into dfco by working on the negative deltatps portion of the table...and the VE table is unused in a MAF setup...
-Matt
Old 03-24-2014, 03:37 PM   #134
mdrobnak
After putting spark control back to DME, I realize that the power level I'm at is already quite fun.
I have some maintenance items which need to be addressed on the car, and at that time the ProEFI will be uninstalled. When I know what's happening for certain, I'll start a new thread with the new plan.
-Matt
-Matt
Old 03-28-2014, 11:22 AM   #135
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
-Matt
Good to hear you are back to enjoying the car Matt.
I don't care who makes the hardware, if you using it makes you frustrated, a change is needed.
Old 04-02-2014, 08:38 PM   #136
mdrobnak
I have it up for sale:
http://forum.e46fanatics.com/showthread.php?t=1031287
If anyone has any suggestions of other places to put it up, they're appreciated.
-Matt
-Matt
