Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Old 10-27-2013, 01:32 AM   #21
red375
My Ride: //HPF E46 M3 stg2
Thats great man !
red375 is offline   Reply With Quote
Old 10-27-2013, 08:10 PM   #22
GRK///M3
My Ride: LSB M3
Re: Tuning an HPF car for 50/50 water meth
I must say that the happy camper is me. Being3 has been a great help to me with setting up my base tune and pump meth tune. I have to say that car has performed flawlessly up to this point. It pulls so hard it unbelievable.
Being3 knows what he is doing when it comes to tunning and is a great help to fellow enthusiast.
Thanks for everything. I will being posting my build that was completed by Lab22 shortly.
GRK///M3 is offline   Reply With Quote
Old 11-11-2013, 11:41 PM   #23
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
To address back pressure and more efficient cylinder scavenging as a result of higher boost with 50/50, I added an electric open dump to my car with 3 inch straight back section two which in turn connects to the muffler.
I had to adjust the 50/50 tune considerably. In fact above 6900 rpm I am not removing any fuel to compensate for the 50/50 mix as the AFRs r perfect. I attribute the exhaust and resulting increased power now being made at high rpm. Also at 3000 to 6500 I had to dramatically reduce the amount of fuel being taken out. For example I was with old exhaust taking 10 percent fuel out from 3 to 4 k rpm. Now I'm only taking 3 percent. So I suspect that I am making some real power gains particularly upstairs... Possibly closer to 800 wheel... Dyno will confirm... It also means that I have exceeded the 1000cc injector and could use a second one above 6500 for even more oomph
So this poses an interesting situation. If u have closed exhaust and open dump would require two different maps. So what I will do is configure the race switch to adjust for the fuel difference and trip the exhaust cutout. I will need to create a small circuit for 5 second power up that will trip a relay to open / close of the exhaust cutout wired into to the race switch. I will also like to have the race switch converted/ moved from the steering column to a foot switch on the dead peddle like the old high beam switch used in vintage cars. This will allow me to have my hands free to press it on or off with a quick tap of my foot.
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 11-26-2013, 11:44 PM   #24
being3
Modded ///Member
being3's Avatar
50/50 Water / Meth Dyno made 742 rwhp and 685 rwtorque compared to Pump @ 654 rwhp & 600 rwtorque. So a peak gain of 88rwhp and 85 foot lbs over a stout base tune. Also gains of 100 hp and 100 torque @ 5750. Numbers r with exhaust cut out open. More Dyno numbers compared to my old exhaust on my other thread "Buying a used HPF M3" keep in mind that the AIT were high above 6500RPM and the timing was being pulled by some 2.5+ degrees compared to normal AITs which r in the 20s C range so the numbers r higher in reality , also 5th gear pulls because of traction which builds lots of heat....
FYI: water temps were between 74c and 82c max on all runs...
50/50 final Dyno numbers
Pump Dyno numbers
It's a stump puller
FYI : I'll post an overlay of the two soon as I get it.
Old 04-01-2014, 12:04 PM   #25
being3
Modded ///Member
being3's Avatar
Just tuned a stage 2 HPF car for water meth 50/50. Also did my DME mods and Aem serial Gage ...
Made 638 rwhp and 510 rear torque.... This was last run of the day... Car ran 15 psi with about 4 degrees more timing... It was interesting to see how high compression motor worked with 50/50 verses low compression..... High compression likes more timing with little boost increase to make power.... I didn't even reach knock threshold as I felt this was the safest limit for stock internals. The car would have made more
Car is fast.... Lebanese nation hill climb champion drove me through the streets of Beirut with it... And we were freaking sideways and did a few 180s through the the side streets with cars all over the place.... It's was awesome. Lol if I were back home I would have been put in Jail indefinitely. ... Got a like it....
Doing a stage 3 in the afternoon tomarrow as well as stage 2 with high compression forged internals .... Stay tuned
Old 04-01-2014, 12:36 PM   #26
lrinco01
My Ride: 01 Turbo M3, 10 'X5M
Send a message via Yahoo to lrinco01
AWESOME!
Anthony, it was great meeting you this weekend in Dubai as you came to re-tune Dragos HPF Stg2.5 M3
have fun in Istanbul with those Beasts!
Leonel Aka " Rico"
BMWCCA # 403748
01 BMW E46 M3 / 6 SPD / Tiag / Imola
HPF Turbo....
Custom Built S54
Flex fuel
8XX rwhp
FOR SALE:
http://www.m3post.com/forums/showthread.php?t=727953
Custom Silver CF 6Speed E46 M3 sport steering wheel
http://forum.e46fanatics.com/showthread.php?t=1051908
lrinco01 is offline   Reply With Quote
Old 04-01-2014, 12:45 PM   #27
being3
Modded ///Member
being3's Avatar
Originally Posted by lrinco01 View Post
AWESOME!
We sure had a blast with many laughs...... Dragos's car made great power on stock exhaust... About 719 wheel on pump and straight meth... With 640 on pump
Old 04-01-2014, 07:57 PM   #28
Twin_Turbo_S54
My Ride: M3
AWESOME!
M3 freaks decided to postpone their visit to Istanbul.
be safe out there
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 04-05-2014, 02:11 AM   #29
dragosid
My Ride: HPF 2.5 M3
We'll sure come very soon Mert ... I'm already trying to get some commitment out of them
Pulled the trigger! Built engine + 6766 Dual BB + Open Dump + 15/23 PSI - Holy F#@$ this build is insane!
HPF Stage 2.5 - 739rwhp & 581ft-lbs SAE
best 1/4 mile (ST2) 11.77'@123mph 1.9' R/T on Toyo R888 295/30/19
Porsche Cayenne Turbo S - stock
dragosid is offline   Reply With Quote
Old 09-11-2014, 07:29 PM   #30
6spd_legend
My Ride: acura legend 6spd
I have a non built s54 running a conservative pump tune but making great power w/ e85 (detuned to 675whp for now- was making ~720whp+) on an AEM Infinity. However, I don't always have access to e85 so I'm really itching for more power when I'm on pump and have recently been considering going the WMI route. I've asked a couple of guys with built s54's who say it's not worth the risk, but I feel like WMI has come a long way and the failsafes are now there to really prevent catastrophic engine damage in the event of system failure. Would love to hear your thoughts on the topic of 'safety' and 'reliability' when it comes to WMI.
2001 LSB M3 Coupe
6spd_legend is offline   Reply With Quote
Old 09-11-2014, 11:10 PM   #31
being3
Modded ///Member
being3's Avatar
I have AEM Infinity setup for 50/50 with built in failsafes. I use AEM water meth system with AEM water meth flow failsafe gauge. If any fault occurs with electrical, tank running low, leak or clogged nozzle etc... the system triggers low boost automatically.... nice thing with Infinity is the tuning. U setup a separate lambda table for AFR targets and Infinity automatically adjust fuel for 50/50 using same VE table u already have for ur car. Combined with alternative timing , boost map linked to mode switch u activate it as u wish. The one feature that is a failsafe that's a bit of a pain is u have to have the map at atmosphere to activate 50/50 system. So clutch has to be pushed in. With the power ur making one 1000cc nozzle will take car to all the power a stock motor can handle.
Old 09-12-2014, 12:28 AM   #32
being3
Modded ///Member
being3's Avatar
Infinity with AEM water meth system and failsafes. " Converted HPF system"
Another aspect of making a reliable 50/50 systems is to use DOT connectors and lines. The connectors need to have the O rings replace with AC grade HNBR O rings. This way u will have a leak safe setup.
HNBR O Rings
DOT rated brass fittings retrofitted with HNBR O rings
HPF meth systems replaced with AEM progressive failsafe system
AEM E46 M3 harness modified for 50/50 failsafes.
1100cc Flow sensor modified with a by pass for 2200cc of flow to accommodate duel 1000 cc nozzles
Old 09-12-2014, 04:41 AM   #33
lrinco01
AWESOME!
Simply Amazing upgrade Anthony!
thank you for continually sharing bro
Leonel Aka " Rico"
BMWCCA # 403748
HPF Turbo....
Custom Built S54
Flex fuel
8XX rwhp
FOR SALE:
Old 09-15-2014, 07:41 AM   #34
cosmos328Ci
My Ride: 328Ci -M54B30 on E85
Attachment 536352
Pump Dyno numbers
Attachment 536353
It's a stump puller
Hi being3,
Can you tell me your WOT ignition timing and AFR when you are around 18psi, 50/50 WM and using your 3" cut out?
Cheers
cosmos328Ci is offline   Reply With Quote
Old 09-15-2014, 09:04 AM   #35
being3
Modded ///Member
being3's Avatar
Originally Posted by cosmos328Ci View Post
Hi being3,
Cheers
AFRs should be 11 and ignition timing depends on if ur motor is low,compression or stock. And will vary depending on AIT temps as timing trims r in play. I can post the 50/50 timing map if u let me know ur compression
Old 09-15-2014, 10:07 AM   #36
cosmos328Ci
I'm running E85, 10.2:1 Stock Compression Ratio (M54B30).
AIT after a couple of full street runs go upto about 70-75 Deg Cel, then come back down to around 50Deg Cel - around 15-20sec of driving in outside air temp of around 24deg cel.
I was mainly just asking about your car. Which may not be relevant to my car.
Thanks being3.
Old 09-15-2014, 10:18 AM   #37
being3
Modded ///Member
being3's Avatar
Thanks being3.
My car is running around 5 degrees at WOT with trims at 26psi and at 18 psi I'm only running 94 octane and NO 50/50. One thing is u don't need water meth for e85 as it has the cooling characteristics built in and that's why e85 is so good at making power not its octane rating as some might think ... E85 should be able to run a lot more timing
Old 09-15-2014, 09:36 PM   #38
cosmos328Ci
Thanks for the info being3.
I'm gonna run 50/50 before my twin screw to help reduce the temps when being compressed.
Running 22 Deg WOT at 18psi atm with out WM.
