Sponsored by The Tire Rack
Old 10-10-2013, 11:18 AM   #21
Krolli96
My Ride: 2001 330i
Re: What are good stretched tire sizes for 18x10
This is when I start feeling old because "stancing" looks horrible to me and I guess ruining your car is the cool thing to do now.
Sent from my Nexus 7 using BimmerApp mobile app
Krolli96 is offline   Reply With Quote
Old 10-10-2013, 12:29 PM   #22
kwikE46
My Ride: 2004 BMW 325i
I run a 9 inch wheel in the rear, and a 8 inch in the front. Fits very well. No rubbing, even with a slightly taller tire. Factory suspension, bilstein HD shocks/struts.
If i had to do it again, i would go with a square set up to be able to rotate the tires. If you dont, just make sure the alignment is completed properly and all settings (toe,camber,caster) are set
to the correct angle.
That being said, i do not see a 10 inch wheel fitting a non-m e46 without modification. With the 9inch wheel i have now, it sits damn near flush with the fender. Looks clean and tasteful.
I can post some pictures, or text them to you like a did for a member not too long ago!
Good luck with everything!
kwikE46 is offline   Reply With Quote
Old 10-10-2013, 02:32 PM   #23
Zell
Zell's Avatar
My Ride: so turbo wow
I've seen too many catastrophic blowouts from stretched tires to morally give you a suggestion.
Old 10-10-2013, 05:49 PM   #24
ZackE46
My Ride: BMW 328ci, BMW 325ic
Im ordering 10.5 inch wheels with a 15 offset for the rear on my non m coupe but my fenders are cut, rolled, and pulled. its a lot of body work and its take some experience but ill be running a stretch tire but not a stupid stretch and not stupid camber.
ZackE46 is offline   Reply With Quote
Old 10-10-2013, 05:54 PM   #25
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
What is "good" is subjective. OP, I would not recommend that wheel sizing, and if you are set on running something like that, the tire size really is going to come down to how much work and effort you're putting into making them fit. Obviously the more your massage your fenders to add clearance, the larger tire you can fit.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 10-12-2013, 07:10 PM   #26
E46Beamer831
My Ride: 2003 E46 325i 4Dr
Ok I see thanx. for the info so maybe I have made a mistake by getting 10 inch
E46Beamer831 is offline   Reply With Quote
Old 10-12-2013, 07:11 PM   #27
E46Beamer831
Ya send me some pictures please
Old 10-12-2013, 07:13 PM   #28
E46Beamer831
U think if I get 18x8.5 in the front it will fit alright ?
Old 10-14-2013, 08:29 AM   #29
kwikE46
Absolutely. There is a little room to spare. Just make sure you run an appropriate sized tire to fill the gap, especially if you aren't lowered.
Send me your number in a PM, and I'll send you some pictures
Old 11-11-2014, 04:19 AM   #30
Lunatic
My Ride: 2007 335i
F**k yeah bro! Hey can you send me some pictures of your setup? I want do a similar setup!
Lunatic is offline   Reply With Quote
