Brake Pressure Switch - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 10-10-2013, 01:35 PM   #1
Brissyjohn
My Ride: 2007 MX-5
Has anyone ever replaced a brake pressure switch? See item 2 on the diagram.
If you have:
How did you remove the electrical plug?
Are there any other traps with the job apart from losing brake fluid?
Brissyjohn is offline   Reply With Quote
Old 10-10-2013, 01:42 PM   #2
WDE46
My Ride: '13 128i, '04 330Ci
That's a simple plug in connector just like any other on the car.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 10-11-2013, 06:05 AM   #3
Brissyjohn
My Ride: 2007 MX-5
Okay, so does it just simply pull off or is there some trick to get it past any "wedge" locks that are there - see the image below with what appears to be a locating/locking wedge shape on the plug end:
Old 10-11-2013, 01:21 PM   #4
raykelly
My Ride: 2004 330i Touring
Did this last weekend.
I used this guide.
http://autotecdirect.wordpress.com/2...r-replacement/
Have a Litre DOT4 handy.
When you take the sensor out it will drain fluid pretty quick so be ready to swap as quickly as possible. Push plenty rag underneath to catch fluid.
The plug has a clip that just needs to be pinched between finger and thumb.
Make sure you have a FLEXIBLE HEAD RATCHET SPANNER 27MM, to get the leverage.
Finally you should also use INPA to bleed by activating the DSC. Works pretty well. Just in case you get air into the DSC.
raykelly is offline   Reply With Quote
Old 10-11-2013, 03:00 PM   #5
Brissyjohn
My Ride: 2007 MX-5
Thanks for that raykelly.
The DSC and Brake orange lights have gone out again and the codes (5e20 and 5e24) were cleared. I'll wait until they come on for good as the switch costs AU$390 (each) here....and that's the club discount price. Extortion IMO
Old 10-11-2013, 03:04 PM   #6
WDE46
Have it shipped from the US. Is that possible?
Old 10-11-2013, 03:15 PM   #7
Brissyjohn
My Ride: 2007 MX-5
Yes, good idea. Is there anyone you guys might know that I can rely on to sell me the correct part and send here?
I'm very wary of getting shafted by internet traders - I haven't had a lot of luck in that area.
Pelican (who I would trust) have a pressure switch but it is the wrong part# and looks like it might be off the earlier cars. Mine is a 2003.
Old 10-11-2013, 03:18 PM   #8
WDE46
Call ECStuning or FCPeuro and see if they can help you out.
Old 10-11-2013, 03:42 PM   #9
Brissyjohn
My Ride: 2007 MX-5
Thanks WDE46. I'll give them a try.
Old 10-11-2013, 03:44 PM   #10
ApolloTheGod
My Ride: E92, E46, E36, Caddy
This is a good time to flush your whole system. Id go unhook the bracklines on all corners of your car and have buckets ready and do a thourough flush. Dosnt bmw reccommend this every 2 years?
ApolloTheGod is offline   Reply With Quote
Old 10-11-2013, 04:11 PM   #11
WDE46
Not that way. You just run the bleed screw until new fluid comes out.
Old 10-11-2013, 06:36 PM   #12
Brissyjohn
My Ride: 2007 MX-5
Mine was flushed about 12 months ago during an Inspection 1.
Old 10-12-2013, 01:12 AM   #13
raykelly
The lights would come on randomly for me. I swapped the cables and then using INPA (I love INPA) could see that the fault moved from one sensor to another - proving the faulty sensor. Luckily the sensor hard failed and the lights were on all the time now just before I changed it - so there was no doubt.
Using INPA to bleed the brakes activating the DSC is very effective - getting out that fluid that has been in the DSC.
Even though I have a Motive pressure bleeder I think this is the most effective way of bleeding brakes.
This is a common part to fail on these cars it would seem - but a relatively easy DIY.
INPA link http://forums.bimmerforums.com/forum...o-bleed-brakes
Old 10-12-2013, 05:10 AM   #14
Brissyjohn
My Ride: 2007 MX-5
Yes, they've been random for me too over the last 18 months but were stuck on for a couple of days and then went away on Friday - crazy car.
ECS Tuning have the part and I have emailed them to get a price shipped to Oz. Should hear back next week.
I don't have INPA but will look into that.
Old 10-14-2013, 03:56 PM   #15
Brissyjohn
My Ride: 2007 MX-5
Folks, I'm looking at buying my own scanner that will read and clear DSC and ABS system codes (as well as others).
I have a laptop running Windows Vista.
Which would be the better device?:
BMW Scanner 1.4.0 http://www.xcar360.com/bmw-scanner-1...scan-tool.html
or
Ediabas Inpa DIS http://www.ebay.com.au/itm/BMW-OBD-D...item3f17d6b808
Old 10-14-2013, 07:56 PM   #16
WDE46
Most people get the BMW Scanner 1.4.0 from xcar360, myself included.
Old 10-15-2013, 12:21 AM   #17
Brissyjohn
My Ride: 2007 MX-5
Will it read ABS and DSC faults? I believe some code scanners will not.
Old 10-15-2013, 08:20 PM   #18
WDE46
It reads all BMW specific codes.
Old 10-21-2013, 02:15 AM   #19
Brissyjohn
My Ride: 2007 MX-5
Well the stupid lights are on again.
I'm ordering the parts tomorrow and will hopefully have them by the end of the month.
I'll also get a flexible head ratchet spanner and have a go at replacing both pressure sensors and update this thread at the conclusion.
Thanks for the help and advice guys.
Old 10-30-2013, 06:10 PM   #20
Brissyjohn
My Ride: 2007 MX-5
Lights went out again on about 23 Oct and came back on again on 29 Oct...grrr.
Parts have not arrived yet.
