Sponsored by The Tire Rack
Old 10-10-2013, 03:39 PM   #1
Zell
Zell's Avatar
My Ride: so turbo wow
How long have your rear tires lasted you?
Trying to gauge here how I should expect my rear tires to wear in comparison to my front. It seems like my fronts are hardly wearing, while my rears are wearing more quickly.
I don't do burnouts or anything, and people have said it is normal for the rears to wear faster than the fronts on RWD cars.
Old 10-10-2013, 04:16 PM   #2
My Ride: Lexus
it's not so much "RWD cars," it's the way BMW alignments are set up for ***** ******* and ********** under ************ and *********.
In a nutshell, it's normal.
I get 17-25k out of mine and that's with quite a bit of canyon time with a lot of tread life to spare.
Old 10-10-2013, 06:31 PM   #3
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
This is pretty common on BMWs. Seen it on some of the associates cars, and they're in the same boat. Alignment checks out, driving hasn't been too aggressive, etc.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 10-10-2013, 09:10 PM   #4
Brevik
My Ride: Tiag M3
I am thinking my rears will be toast at 15-17k and they are wearing evenly.... I never burn the tires btw.
Brevik is offline   Reply With Quote
Old 10-10-2013, 10:06 PM   #5
Llink78
My Ride: 2002 330i
I probably get about 2 summers out of my rears. i run Hankook V12's the fronts will probably last a year or 2 longer than the rears. The tread-wear is 200 though
Llink78 is offline   Reply With Quote
Old 10-10-2013, 10:45 PM   #6
Swater330i
My Ride: 2003 BMW 330i 5MT
Ran Pirelli tires in the rear for 25k with no drifting or burnouts but rough driving and had a blowout on the right side on an on-ramp. So I change the rears every 20k now, fronts are still good after about 30k miles but will be replaced soon.
Originally Posted by phenom323ci View Post
I am going to install M3 fender grill on my 323ci.
Originally Posted by futureSubie View Post
IMO, the euro clear corners looks too aftermarket/ricey.
Originally Posted by Davconelectric View Post
This 323 would most likely handle and drive better than a stock e46 m3.
Swater330i is offline   Reply With Quote
Old 10-10-2013, 11:42 PM   #7
CharlzO
My Ride: 2000 328ci
I've found it typical in a RWD car. They're providing the drive for the vehicle, and even have that little bit of sideways wear on corners, whereas the fronts just roll along, and turn in, etc. That, and some tires are going to be a lot more prone to wear just in their design. A high performance, softer tire is generally going to wear faster than a harder compound. I had some Khuma Ecsta SPTs on last summer, and burned through those like no tomorrow in a few months worth of driving, nothing heavy, just normal day to day. Switched to Hankook Nobles this year, All-seasons to also prep for winter, and the treadwear rating is a ton higher than the others, and I've barely noticed any wear front or rear in the 6 months they've been on.
CharlzO is offline   Reply With Quote
Old 10-11-2013, 09:42 AM   #8
Zell
Zell's Avatar
Thanks guys, good to know. These are about the numbers I'm getting with my tires as well.
Old 10-11-2013, 09:43 AM   #9
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Most see about 50% wear on the rear tires vs the fronts if the tires are not able to be rotated.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
